Blondie has chafing between the legs..... |
Joe Bob |
Jan 1 2004, 11:12 PM
I have a rubbing on the inside wheel wells due to a chassis stiffening kit. I need to space out the wheel to lower the rear and try and get some more negative camber....what is the minimum number of turns that a lug nut have to be safe and/or legal for DE or AX?
I can always add longer studs but I would like to avoid the labor if I don't have to....or should I just use open top nuts and see if the studs pass the top of the nut when fully tightened? |
Gint |
Jan 1 2004, 11:21 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
There is actually a spec (SAE?) for fasteners regarding the amount of thread engagement of a nut on a bolt. I don't remember what it is. I think I heard soemthing about this from Geoff at one time or another.
After thinking about it, it might have been Sammy. This post has been edited by Gint: Jan 1 2004, 11:22 PM |
J P Stein |
I use the 7mm spacers and put on steel lug nuts....IMO, the stock stud ain't doing the trick. I get about 6 turns, 9 would be better or one thread past the nut, better still.
I'm getting longer studs. |
Jan 1 2004, 11:41 PM
somehow, the number 7 comes to mind ....
where's brad when you need him? Andy |
Gint |
Jan 1 2004, 11:45 PM
It's starting to come back to me. I vaguely recall a measurement. Something like the bolt should actually engage all of threads on the nut, plus an additional 1/3 of the thickness of the total threads on the nut.
But what do I know. |
Carrera916 |
Jan 1 2004, 11:46 PM
Member Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 |
I would have to agree with JP as from my experience watching & working on race cars, we always put a longer stud on with the idea of at least a thread or two sticking out of the nut. You would want the full clamping force on the wheel expecially if you're gonna drive her hard around the corner....
j |
Brad Roberts |
Jan 2 2004, 12:48 AM
This is from PCA:
"Wheel bolt/lug nut engagement must be at least one times the bolt/stud diameter." This is nine turns on a Porsche set-up. NHRA is different.. (IMG:style_emoticons/default/laugh.gif) (burnout Z) B |
ArtechnikA |
Jan 2 2004, 06:30 AM
QUOTE(mikez @ Jan 1 2004, 09:12 PM) ....what is the minimum number of turns that a lug nut have to be safe and/or legal for DE or AX? ...should I just use open top nuts and see if the studs pass the top of the nut when fully tightened? the Zone 8 spec used to be "end of the stud and tight". my roadwheels barely meet this spec with stock studs and no spacers (fat cast pseudoFuchs). i suppose i could have 0,1" milled off the lug nuts to make them legal, but somehow i don't think that's what they meant... i can send you a spare steel lug nut if you want, but i have to believe you have a source closer than me ... i believe the generic thread engagement spec is 1.5 x the diameter of the stud. just bite the bullet and install 100mm studs with NASCAR ends ... |
Lo-Fi Version | Time is now: 17th May 2024 - 04:16 PM |
