What did you do to your teener this past weekend?, anyone making any progress? |
brp986s |
Nov 25 2007, 09:33 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
joined the mile high club. ok, 4 ft, but really helped with a speedo angle drive replacement. No more shimmying around on my back.
Attached thumbnail(s) |
hwgunner |
Nov 25 2007, 09:46 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
I lowered the fuel level a couple times. Once with a friend and the other a blast by myself.
dflesburg |
Nov 25 2007, 09:57 PM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
On my car, I broke the fan belt on my 3.2...
On Erik's car, (Great Pumpkin) I tried for 3 days to weld a allen into the drivers side torsion bar adjustment bolt so it would come out, broke all 12 attempts... |
type47fan |
Nov 25 2007, 10:06 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
. . . began the caliper change on the 911 front end for my V8 conversion . . . .
PeeGreen 914 |
Nov 25 2007, 10:09 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I put my new Triad racing exhaust on my car. It weighs a total of 12lbs and sounds great. The only downer is it just doesn't look as cool as the other Triads. I did drive it a lot in 25 degree weather. Sometimes I do wish I had heat.
KaptKaos |
Nov 25 2007, 10:48 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Put in my new jets in my carbs (mains, airs and idles) and mounted my breather box.
Tomorrow I plan to adjust idle and maybe go for a little drive =) |
euro911 |
Nov 25 2007, 11:21 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Not much 'work' got done here ... I caught a pretty nasty cold (IMG:style_emoticons/default/mad.gif)
BUT ... on Friday, took my brother on a drive through the twisties around the Palos Verdes peninsula in my wife's car. We needed to verify good roads for next Saturday's San Pedro/PV run. He hadn't been in a 914 in over 30 years. Since I was stuck inside, a friend dropped off a Gum Ball Rally DVD to help cheer me up (IMG:style_emoticons/default/biggrin.gif) INTERESTING NOTE There's a scene with a silver 914 in it, never saw this before (IMG:style_emoticons/default/sad.gif) ... my wife spotted it (IMG:style_emoticons/default/cheer.gif) ... sort of at the beginning, just after they've all started the race ... just after the little Italian guy drives off in the Rolls Royce with his girlfriend after her photo-shoot (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
computers4kids |
Nov 25 2007, 11:26 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
Sold my 72 this weekend...sorry to see it leave, but it went to a good home and a bright future.
Now...I can focus on just one project and maybe get something done. |
woobn8r |
Nov 25 2007, 11:40 PM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
Well....It's been Fuchin' cold here,.... so all I got done was put away the old wheels and tires with the summer tires from our daily drivers.....
At least there's nothing on the garage floor except 4 jackstands (holding a 914) a TIV with 901 beside it....and an engine stand with a fresh 3.2! |
brer |
Nov 25 2007, 11:57 PM
Advanced Member Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None |
I took the advice Howie gave me in 2005 and spent the weekend installing the front sway. Used the crossmember as a reference to get them the same height.
McMark |
Nov 26 2007, 01:50 AM
Some inspiration for ya' Dan. (IMG:style_emoticons/default/wink.gif) That is a sweet carpet kit... Who makes that mark?Larry, that's a Morph carpet kit (he's a member here, see the Member Vendors section) and a custom firewall carpet piece made by my upholstery guy. He cut the carpet and sewed the edges with some black stuff to give it a nice finished look. |
type47 |
Nov 26 2007, 07:54 AM
traced continuity on the relay board to try to see if it was the cause of the car quitting twice on the way to have some work done on it last weekend. no faults found so i used a dremel to clean all the pin contacts and fuse contacts to avoid corrosion faults. other than that, i pulled back the end of the tarp to see if the car was still orange! i did install 3 roof windows on the garage and started shingling (IMG:style_emoticons/default/smile.gif)
purple |
Nov 26 2007, 08:10 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I made an engine cart out of a single 2x4 and 4 casters and a box of screws from home depot. Grand total 18 bux to make ( I couldnt find one anywhere!) I then dropped the engine! First time i've ever done that!
Turns out I've got a GD case from a bus! the cooling fan has a ton of broken blades. At least the main seals look like they're in good shape. I have 1.7L heads on a 2.0L engine yippee Attached image(s) |
0396 |
Nov 26 2007, 08:28 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
my car is basically done except for little things that bug me. Like the brake calipers were dirty and rough to the touch. So some bead blasting and some ceramic caliper paint... (IMG:style_emoticons/default/smile.gif) also repainted my rocker panels and rear valence. They had taken a beating this year from AXing and Track events. (mostly from AX venues). put on the street tires and wheels for the winter. next will be removal of stock back pad and recarpeting the entire interior including the rear bulkhead wall. Dan, Looks like you're on the way to some fun!... as for the question, what I did to my 914, After my three days at B/W last month, I readjusted my front sway bar. This adjustment made the car respond better. I guess I wil know if this was a good move or not next month at the OC PCA 'El Toro' event. Thanks for sharing |
Gint |
Nov 26 2007, 08:52 AM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I drove mine once. Topless. Does that count?
I had to put the top on this morning before driving to work. It was only 23 degrees at 06:30. |
army dude |
Nov 26 2007, 08:59 AM
The answer is 42 Group: Members Posts: 218 Joined: 12-December 05 From: Sarasota, Fl Member No.: 5,265 |
Drank lots of coffee to pass the time so Monday would come quicker so I can go pic up my car with a framed rearend to hold the 930 tranny. Pics to come soon!!
Ian 678-458-0770 |
Phoenix914 |
Nov 26 2007, 09:09 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Put in a new thermostat cable, as the old one was frayed on the end. Also had to replace the small bolt and square nut that holds it to the flappers. Now I'm not sure if the thermostat is good or not. Isn't it supposed to be compressed when it's cold? Anyway, the engine warmed up better on the shake down drive.
rick 918-S |
Nov 26 2007, 09:44 AM
Hey nice rack! -Celette Group: Members Posts: 20,471 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Worked on the Alien Autotopsy. Started here... Two on the opporating table.. Ended with one on the gurney.. (IMG:style_emoticons/default/smile.gif)
Cevan |
Nov 26 2007, 11:01 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Put in a new thermostat cable, as the old one was frayed on the end. Also had to replace the small bolt and square nut that holds it to the flappers. Now I'm not sure if the thermostat is good or not. Isn't it supposed to be compressed when it's cold? Anyway, the engine warmed up better on the shake down drive. I checked mine this weekend. I also have a broken cable. I took a heat gun to it and after about 20-30 seconds (didn't want to melt it) it expanded like an accordion. I assume that to connect the cable correctly, you want to compress the flaps (the opposite of their default condition) and then connect the cable, getting out all the slack. |
BMXerror |
Nov 26 2007, 11:07 AM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Lo-Fi Version | Time is now: 31st May 2024 - 09:24 PM |
