New Fuel Pump, How to Prime |
warrenoliver |
Dec 1 2007, 09:10 AM
Member Group: Members Posts: 363 Joined: 11-November 06 From: McFarland, Wisconsin Member No.: 7,199 Region Association: Upper MidWest |
I just got a replacement fuel pump (73 2.0 in the original location),because I couldn't get the previous replacement one to pump. (IMG:style_emoticons/default/headbang.gif)
So, before I go and muck it up, how exactly do I prime this thing. The directions from HPH say " Squirt oil in pick up port to help prime the pump. Repeat if necessary" - seems pretty easy, but the last one I got, no matter how much oil I pushed into it, the darn thing would only pump out of the return port, not the "D" port. So, what is the trick? I will be testing this one on the bench first before installing under the car like last time - should prevent another gas shower! Thanks. Warrenoliver |
swl |
Dec 1 2007, 09:37 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
I'm not one for ignoring directions but after the time I've spent under the car replacing old hoses I can pretty much guarantee you that gravity will prime it just fine. The delivery hose was leaking and I had to clamp the supply to keep it from gushing as I replaced the line.
IMHO the 'return port only' issue isn't priming - The rubber tit on the end of the pop off valve is sticking and the fuel flow can't provide enough pressure to break it free. Hmm. In writing this I am confusing myself. (old age!). The way that bypass valve works I should never see fuel flow on te delivery side without fuel pressure. Don't know where all that gas would have come from. Never the less I would just slap it in and let it pump - especially if it is on the bench. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:01 AM |
