I just got a replacement fuel pump (73 2.0 in the original location),because I couldn't get the previous replacement one to pump.
So, before I go and muck it up, how exactly do I prime this thing. The directions from HPH say " Squirt oil in pick up port to help prime the pump. Repeat if necessary" - seems pretty easy, but the last one I got, no matter how much oil I pushed into it, the darn thing would only pump out of the return port, not the "D" port.
So, what is the trick? I will be testing this one on the bench first before installing under the car like last time - should prevent another gas shower!
Thanks.
Warrenoliver
