VR6 in a 914 |
VR6 in a 914 |
1bad914 |
Dec 6 2007, 02:25 PM
Senior Member Group: Members Posts: 618 Joined: 6-May 04 From: Battle Creek, MI Member No.: 2,028 |
Has anyone done this?I have access to a low mileage motor and was just wondering?
lotus_65 |
Dec 6 2007, 02:33 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
it's been talked about, i don't remember if it was done. it would be cool!
there's a passat vr6 around here i just noticed. (IMG:style_emoticons/default/idea.gif) |
1bad914 |
Dec 6 2007, 02:45 PM
My son has a low mileage VR6 Jetta that was rolled, engine would be free, I'm sure an adapter is out there or could be made by someone???Hmmmm
AZ914 |
Dec 6 2007, 05:15 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Was Mike Mueller working on this at one time?
neo914-6 |
Dec 6 2007, 05:19 PM
jonferns |
Dec 6 2007, 06:14 PM
theres currently a vr6 swap project (914) for sale on the samba. I ran across it yesterday.
VaccaRabite |
Dec 7 2007, 08:50 AM
En Garde! Group: Admin Posts: 13,445 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am pretty sure that Kennedy makes and adapter plate for the Vr6 to the 901. I am also pretty sure that to make it work, you will be loosing your rear trunk (which is not a big deal to some people, and is for others. And as long as you are loosing the rear trunk, you have room for a turbo or supercharger - which the Vr6 loves as much as pigs love stink. Its a neat way to keep the 914 in the "family" and still have a wicked fast car.
Zach |
1bad914 |
Dec 7 2007, 09:19 AM
I can vouch for the potential of the VR6, my son now has an R32, amazing car. I may delve into this a little deeper. It would be one heck of a fun ride. As usual cooling would be an issue as the VR6 is prone to overheat!
I looked on The Samba and could not find the VR6 914 swap? |
Cap'n Krusty |
Dec 7 2007, 09:25 AM
If that "low mileage" is anywhere over 70K, replace the conveniently located timing chains and assorted bits before you do the swap. It's a more than one day job when it's in the car, and a known problem. The Cap'n
VaccaRabite |
Dec 7 2007, 10:30 AM
http://www.kennedyeng.com/vw_por.htm#6CYL
There is the link to Kennedy Engineering for the adapter plate to mate the Vr6 to a 901. You will need to make a custom engine mount bar, and as I recall, you will need to loose the rain tray, or you will have very low ground clearence. I totally think you should do it. When I had my MkIII golf, I was constantly cursing the fact that I had bought the 2.slow instead of the Vr6. Zach |
Cap'n Krusty |
Dec 7 2007, 10:48 AM
2.0 timing belt job, retail ........... 300 bucks
VR6 timing chain job, retail ........ 2000 bucks Same mileage interval Take your pick The Cap'n |
VaccaRabite |
Dec 7 2007, 10:52 AM
2.0 timing belt job, retail ........... 300 bucks VR6 timing chain job, retail ........ 2000 bucks Same mileage interval Take your pick The Cap'n Hey, stop injecting reality into my fantasy! (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/biggrin.gif) |
1bad914 |
My son has had many Vr6 cars, he knows them very well. I'm going to call him about the motor.
lotus_65 |
Dec 7 2007, 11:10 AM
Pat Garvey |
Dec 7 2007, 08:16 PM
If that "low mileage" is anywhere over 70K, replace the conveniently located timing chains and assorted bits before you do the swap. It's a more than one day job when it's in the car, and a known problem. The Cap'n As an owner of a VR6 (love it-hate it) Passat I'd pick another motor! I've put $7k into that motor, ith only 72K miles on it. Why, it's my wifes car & she love it. But, one more dime & the car gets donated! When it runs right, it runs like stink. But, when it doesn't - it's expensive. Don't need Ferrari-like problems in a Porsche, particulary since it doesn't pusch huge hp. There are better motors. |
okieflyr |
Dec 7 2007, 09:03 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
Since your son knows his way around the VR6, he could set up your engine managment. Save your money on the Kennedy adapter/clutch set up. With the power you'll have, you may not be happy with the stock 901 gearing. I used their setup, and it worked fine, but with the new level of power, I wanted a stronger trans.(flame suit on) You "may" be able to bolt up a Passat tranny and have better gearing. BUT check out if there are ANY differences in the blocks FIRST. My 1.8T transverse block is not going to bolt up to my newly built up Passat trans upgrade. I'm going to have to get a longitudinal Passat 1.8t block to finish my upgrade.
Gary |
Dec 7 2007, 09:38 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
I floated the question of a VR6 conversion a little while back: VR6 thread. I think a more robust boxster or audi tranny will bolt up, eliminating the 901 as a weak link. Never got past the concept stage though...
bernbomb914 |
Dec 8 2007, 01:38 AM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I think that muller said that it was to big and would not fit with out a lot of work. measure it before you invest
effutuo101 |
Dec 8 2007, 02:42 AM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Having been a VR6 owner and some what jaded, I wouldn't bother. Besides the over heating issues, the oil pickup is to close to the bottom of the oil pan and is prone to starve the engine of oil. Ask me how I know and I will tell you how much I don't like that motor. If you are going to stay VW. go with the TDI or the 2.0 Turbo. Much better return on investment is my thought. If the suby flat 4 TDI motor is all it is cracking up to be, that might be another though.
neo914-6 |
Dec 8 2007, 01:47 PM
Here's Muellers thread
Lo-Fi Version | Time is now: 21st May 2024 - 11:03 AM |
