Shift Knob has me stumped |
familienauto |
Dec 11 2007, 12:50 AM
Volksporsche Group: Members Posts: 136 Joined: 5-November 06 From: UW Seattle Member No.: 7,156 Region Association: Pacific Northwest |
I had some time today so I was doing some little stuff on the 914 - I did successfully take the fuel gauge apart and fix the little bezel that had fallen off inside. That was fun (IMG:style_emoticons/default/slap.gif)
Anyway, ever since I took the shift knob off when I redid the carpet I haven't been able to get it back on as tightly as it used to be. I have the standard shift knob and the little original metal crush sleeve. If I put the crush sleeve on the shifter and then push the knob on, it stays loose. If I drop the crush sleeve in the knob and try to push it on, I can't get it on...maybe I am just not pushing hard enough? Or maybe I need a new crush sleeve? Are they a 1-time use item? Thank you for answering my dumb questions. Zach |
914-8 |
Dec 11 2007, 01:00 AM
Senior Member Group: Members Posts: 802 Joined: 23-January 06 From: Cal Member No.: 5,461 Region Association: None |
They can sometimes be reused, but they do wear out. A new one is like $2.
RoadGlue |
Dec 11 2007, 02:11 AM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
Hi Zach,
My stock shift knob uses two of the crush sleeves. Could it be that you're just missing one? If it wasn't loose when you removed it, then I doubt anything was too worn out. |
davep |
Dec 11 2007, 07:17 AM
I don't think you should be using two crush sleeves; I've never seen that.
The whole thing is a familiar problem, but I cannot recall my solution years ago. I think when you put the sleeve on the lever it slides down out of place. I think when you put the sleeve in the knob it is too tight to get started. What you might do is use a bit of crazy glue to hold the sleeve to the tip of the lever, and then put the knob on. Or you might try the sleeve just started on the tip of the lever, but mostly in the knob when you start; that should allow it to go all the way into the knob and remain started on the lever. Yes, you may have to use considerable force. |
Eric_Shea |
Dec 11 2007, 10:49 AM
Just did this two weeks ago. Seperate it slightly and put it "just" inside the knob. Push. Tighten with a back and forth movement while pushing. Enjoy.
rhodyguy |
Dec 11 2007, 10:58 AM
there is also a slight "step" in the very bottom of the hole. sometimes the sleeve may be hung up on the step and it doesn't snug up when you push the knob on.
k |
Jeffs9146 |
Dec 11 2007, 01:14 PM
Be gentle! The knob will crack if done wrong!
stevesc_us |
Dec 12 2007, 04:26 PM
Member Group: Members Posts: 71 Joined: 12-February 06 From: Redwood City, CA Member No.: 5,569 |
Lo-Fi Version | Time is now: 18th May 2024 - 06:26 PM |
