914 Fuel Injector Substitutes?, Choices... |
JeffBowlsby |
Dec 11 2007, 10:00 AM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I recently set out to identify possible substitute fuel injectors for stock 914s. With the interest in replacement PEFI, I thought it was important to identify any options for this important part. I have not obtained or physically tested any of the injectors below, the information is based only on published data from the internet and hard copy sources available to me.
The easiest solution is to identify identically performing fuel injectors that can be direct substitutes for the original part numbers. Direct substitutes are convenient because they can be installed into new PEFI installations or existing FI systems if original parts cannot be obtained. Criteria here include that the substitute be compatible physically for mounting purposes and identical in function/performance to the original injector. I was hoping to find new alternate injectors for <$50 each that were plentiful, but I could not find anything available. As it turns I found information that the original Bosch pintle-style injectors are a very robust design and are the only physically similar injectors, allowing stock 914 mounting hardware and fuel/electrical connections, which for this option is important. No manufacturer makes anything similar or easily adaptable. Several different Bosch injectors are excellent matches for original 914 injector part numbers, why Bosch offers several seemingly identical injectors with different PNs I am not certain, but there are hints that the injector bodies are very similar if not identical, it’s only the attached hose that is different – short/long, straight or angled. Hoses are easily changed. A side by side comparison and testing would be important to distinguish actual differences. Don’t think that 914 injector flows are hugenormous, The original PN injectors are nicely sized and capable of supplying sufficient fuel for 914 engines with only short duty cycles, which contributes to their durability and long service life. Bosch makes several injectors with comparatively enormous flow rates much greater than 914 injectors. Substitute identical injectors I found were all about the same price, and mostly made for Volvos and Mercedes Benz’ of the same vintage as the 914 using D-Jet fuel injection, which raises a concern. Not only are these substitute injectors no less expensive than the 914 part number, it would seem likely that at sometime in the future when Bosch decides to no longer support 914 injectors they might also drop all injectors of this design and era, so at that time, this straight substitution will not be an option. Who knows when or if that might be? The chart below shows several possible substitute Bosch part numbers that seem to be sufficiently identical to the original 914 injectors. I found at least one source for each of them, with only a brief search. A second solution uses physically identical injectors, but part numbers with different functional characteristics, compensating with PEFI tuning to make them work. I don’t think this is the easiest solution, but it could certainly work well. They should easily mount right up, but one problem is that these Bosch pintle-style injectors that may go obsolete. Another issue is that tuning a PEFI with these parts requires a commitment to those specific parts, or retuning using different parts in the future may be required. Great news though…check out the injectors that are bolt-ins for the 1.8L 914, especially part number 0 280 150 114 for many VWs. I found this PN available from several sources for as little $65 new. They require electrical connector swaps (easy), but there are so many cars that use them, including newer cars than the 914 that they should be plentiful for many years to come. These injectors will require longer duty cycles, but nothing extreme. A third option which I see as the last resort or only for very special needs is to use other suitable injectors of any physical design and functional characteristics. This is the most difficult option, promising at this point in time, little if any benefit to most owners. Newer style injectors could be selected and a PEFI could be tuned to work. Fabrication work would be necessary to configure a fuel rail and other mounting and electrical requirements, which for many is not possible or expensive in terms of time and/or cost. I perceive this to be the most expensive option in time and cost, for undetermined benefit. Thought I would pass what information I found for reference…use it at your own risk. Do you know of any other options? Attached thumbnail(s) |
Cevan |
Mar 25 2009, 10:42 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
I may need a 2.0 injector. Partsamerica.com is gone (the two companies split apparently O'Reilly Auto and Advance Auto). I found these at O'Reilly Auto for $51.99.
These appear to be the same ones jk76.914 is using. |
jk76.914 |
Mar 27 2009, 06:14 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I may need a 2.0 injector. Partsamerica.com is gone (the two companies split apparently O'Reilly Auto and Advance Auto). I found these at O'Reilly Auto for $51.99. These appear to be the same ones jk76.914 is using. Yeah. Those are mine, but like I said, when I received them, three were of the newer ball valve style, and one was like the picture. oreillyauto.com is the new partsamerica.com, same login and password, still has my account info and list of cars...... Next month, I'll give an update as to how the Niehoffs are running. Once I get a few hundred 2009 miles on it. Jim |
Zaffer |
Apr 27 2020, 09:32 AM
Member Group: Members Posts: 96 Joined: 10-December 06 From: Radiant, VA Member No.: 7,343 Region Association: MidAtlantic Region |
Bringing up a long dead thread, but feel it's still relevant.
I am looking to either send my injectors off to have them rebuilt or just get new ones from Rock Auto. I'm considering not rebuilding mine as 2 are in very questionable shape due to rust on the exterior and I only currently have 5 for the 2.0L. I do also have four injectors that were sold to me as being for the 2.0L, but when I checked the numbers, they are actually for the 1.8L (IMG:style_emoticons/default/headbang.gif) The ones from Rock Auto are here: https://www.rockauto.com/en/catalog/porsche...l+injector,6224 Not a bad price at all, but don't know much about this company as far as quality goes. The price for equivalent ones from a MB 450SE are here and almost $20/injector cheaper, but same company: https://www.rockauto.com/en/catalog/mercede...l+injector,6224 Just wanted to get some input since the thread died and no updates were given as to how well the MB injectors did vs. the original 914 ones. FYI: I did a check for the Niehoff ones and can't find them anywhere so guessing they're no longer around? If anyone has any info., please let me know. |
GregAmy |
Apr 27 2020, 01:01 PM
Advanced Member Group: Members Posts: 2,282 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I am looking to either send my injectors off to have them rebuilt or just get new ones... http://www.914world.com/bbs2/index.php?showtopic=343970 |
DRPHIL914 |
Jul 7 2021, 10:15 AM
Dr. Phil Group: Members Posts: 5,760 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I am looking to either send my injectors off to have them rebuilt or just get new ones... http://www.914world.com/bbs2/index.php?showtopic=343970 @GregAmy are you using these injectors with your 2056 build? from reading this thread i see the CC/mn on our OEM bosch was 380, and these are more at like 480, does that work better with the 2056 than stock? Phil EDIT : sorry looks like from this thread its 452CC - http://www.914world.com/bbs2/index.php?showtopic=343970 |
JamesM |
Jul 7 2021, 12:20 PM
Senior Member Group: Members Posts: 1,894 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Figure I would post a couple things here for public record
NOTE: I have not personally tried these but they appear to be a possibility for d-jet cars https://www.fiveomotorsport.com/1968-1973-4...ack-squareback/ I do however run these with megasquirt builds wherever I am using the stock intake runners. https://www.fiveomotorsport.com/a280-a380-h...-fuel-injector/ Bolt on and high impedance so no need to add a resistor setup, higher pressure for better atomization and more accurately sized for our needs |
Lo-Fi Version | Time is now: 1st May 2024 - 08:20 PM |
