Gas Fumes Inside |
Gas Fumes Inside |
EdwardBlume |
Mar 18 2003, 08:44 PM
After the last autocross, I started getting strong gas fumes inside. The strongest smell came from next to the tank on the fill side with what looks like an overflow leak down the side of the tank. Is it the gasket underneath the numerous bolts that's getting old? How do you know when its shot? Who sells the gasket?
I tightened the bolts down last time I replaced the lines but I think one of the bolts is stripped. Could this be my problem? Any ideas? |
Jeffs9146 |
Mar 18 2003, 09:03 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I had the same problem and found that the fuel lines comming out the bottem of the tank were loose. I removed the plate covering the front underside of the car, tightened the nuts holding the fuel lines and the smell went away. Good luck!
Jeff |
si2t3m |
Mar 18 2003, 10:12 PM
914 addict Group: Members Posts: 346 Joined: 9-January 03 From: Qc, Canada Member No.: 119 |
Had similar problem with my 70 914. I finally decided to make a new gasket for the gas cap. Everything is fine now.
Marc-André |
EdwardBlume |
Mar 18 2003, 11:26 PM
What did you make the gasket out of?
campbellcj |
Mar 19 2003, 12:11 AM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I have had fuel sloshing issues out of the overflow/vent opening up in the filler neck, under heavy cornering load (track) conditions. Severe fume problems. I just re-installed an overflow drain tube (fuel hose) and routed it down to the holes in the floorpan under the tank. Problem went away...I wish everything was that easy.
Lo-Fi Version | Time is now: 4th May 2024 - 04:11 PM |
