TeenerTim |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region ![]() |
I'm just thinking about different options for better/cheap performance that are kind of bolt-on. I saw someones flow sheet on the 914 injectors and they were about 100cc. Browsing through e-bay I found Ford 2.3L injectors that were 147cc and Ford Focus injectors that were 200cc. That seems like it might be the equivilent of swapping a 2-bbl carb with a 4-bbl carb. Of course the impedance is different but I'm sure there's a way around that.
I know Jake has said the plenum is restrictive but it also seems like you could open that up with a Dremel. Is this just naive? I was also thinking about building a megasquirt unit that fit inside the stock 914 ECU case as a stealth upgrade. |
Lo-Fi Version | Time is now: 14th July 2025 - 08:36 PM |
