What? No sway bars!, Why do some 914s come with sway bars and some don't? |
angerosa |
Dec 21 2007, 08:30 PM
Member Group: Members Posts: 334 Joined: 21-August 07 From: Reston, VA Member No.: 8,023 Region Association: MidAtlantic Region |
I bought my car not knowing too much about 914s but I did know cars. My car doesn't have any sway bars. But it seems like some came with them. Is it an option or is there some easily observable identifier that lets you know a car came with factory sway bars?
Eric_Shea |
Dec 21 2007, 09:03 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Quite a few did not come with sway bars. I would say more came without than with.
QUOTE easily observable identifier Hmmmmmmm... well, the presence of a stock bar is a step in the right direction. When sway bars were added, most would opt for a less expensive and larger Welmesiter bar or other alternatives so, I would say, stock components would be a hint that it's a good chance the car came with them. Not always the case however. You should be able to see the U-Tabs welded to the A-arms. A nice neat job would "probably" have come from the factory. Check the overall patina, it should be obvious. The real test would be to pull the fuel tank and see if the mounts were added in Germany or in someone's garage (I guess they could have been added in someones garage in Germany but, you get the point). Generally this area would show welding marks as most were installed in a hurry and not re-painted under the fuel tank. Again, not always an indicator as someone might have done a first rate job but... those are rare. If it has a rear bar you could also check to see if the rear mounts were added at a later date or factory installed. If they were factory installed, they would have been painted with the chassis and have the proper backing plates to strengthen the mount on the inside of the trunk. It would be fairly obvious. Hope that helps. |
angerosa |
Dec 21 2007, 09:45 PM
Thanks Eric - I was more wondering why some had them and some didn't? It's obviously better to have sway bars so why didn't they all come with them? And how did the factory decide for instance "this year we're going to make 1000 with sway bars". And why didn't the ones with sway bars have some designation indicating an upgraded suspension?
Eric_Shea |
Dec 21 2007, 11:51 PM
We shall always wonder.
It's one car, with its broad flat hood, that will tell you striaght away if it has bars or not. I hate the handling of a 914 without a bar(s). Never could figure out why it wasn't a manditory piece. Economies of scale I would imagine. |
914Sixer |
Dec 23 2007, 08:54 PM
914 Guru Group: Members Posts: 8,876 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Sway bars first appeared on the 73's with the Appearance Group package. They came standard with that package. Most 2.0L were ordered with this option. 74-76 this was an optional item for all models. Seems like it was a $75 option.
TedK |
Dec 24 2007, 12:27 AM
Member Group: Members Posts: 163 Joined: 1-August 07 From: Thousand Oaks, CA Member No.: 7,961 |
Were the six's treated the same as the fours??
70Sixter |
Dec 24 2007, 10:44 AM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
Were the six's treated the same as the fours?? I do not think 6s ever came with them. My original, bought new 6 did not have them. Many AXers added 15 mm 911 bars. Others bought cheap aftermarket bars that did not pass thru the front trunk. Later versions used a U bolt set-up that bolted the bar mount to the front end after you drilled the necessary holes. There was no Weltmeister yet and not a lot was available. "Charlie Bars" were the hot set-up as I remember it. And you had[i] to have Konis or Bilsteins. |
orange914 |
Dec 24 2007, 07:56 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Sway bars first appeared on the 73's with the Appearance Group package. They came standard with that package. Most 2.0L were ordered with this option. 74-76 this was an optional item for all models. Seems like it was a $75 option. not trying to hijack... but... what exactly does the 73 apperance group consist of? mike |
davep |
Dec 25 2007, 04:57 PM
914 Historian Group: Benefactors Posts: 5,138 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I don't think it was part of the appearance group, but a part of the performance group. The small reinforcement piece in the rear trunk for the rear bar is the usual giveaway that the car came equipped with bars. I'd guess that less than 25% got factory bars. The majority of 1973 2.0 cars came with them, and the 1974 LE cars got them as standard. The tabs on the front A-arms were standard once the sway bars were an available option.
914Sixer |
Dec 25 2007, 05:52 PM
I have an orignal 73 2.0L invoice. I wish I could scan it in. Under the model in the middle of the invoice it says 473644. This is the factory RPO for the options that were on the car. The only option on this car was tinted glass $100. In my German 73 Factory info Service and Training Manual the option 473644 shows the car to be equiped with the Sport and Comfort option. The Sport option was where the f & R stablizer bars came in so I was INCORECT about this being in appeareance package.
1970 Neun vierzehn |
Dec 26 2007, 01:59 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
It's one car, with its broad flat hood, that will tell you striaght away if it has bars or not. swaybars? SWAYBARS?!? We don't need no stinkin' swaybars. Real men don't need no sway bars to compete. No bars in front, no bars in back,....we just swing and sway the 914 way (IMG:style_emoticons/default/laugh.gif) Attached image(s) |
Eric_Shea |
Dec 26 2007, 03:35 PM
QUOTE Real men don't need no sway bars to compete. Nice Chris-Craft ya got there. Correct. Not to compete... but to win, now that's another story. (IMG:style_emoticons/default/lol3.gif) My -6 came without. Funny, the wheel wells always had the indent. Only became an option in 73?? Weird. Word. |
Dec 26 2007, 06:52 PM
Quite a few did not come with sway bars. I would say more came without than with. You should be able to see the U-Tabs welded to the A-arms. A nice neat job would "probably" have come from the factory. Check the overall patina, it should be obvious. Obviously w/o a bar, but the tabs are there. Oberconcoursfuhrer Garvey declares fitmant of a bar would be verbotan. (IMG:style_emoticons/default/laugh.gif) But the car does have excellent, functioning, concours brakes. (IMG:style_emoticons/default/beerchug.gif) Paul Attached image(s) |
Eric_Shea |
Dec 27 2007, 11:35 AM
Have them put a bar in that thing while it's being restored. Where's Scottyb when you need him:
"Put a bar in that teener, it's the right thing to do." I put a factory bar in my -6 when it was being re-done. I was "SOOO" happy I did. It changed the entire attitude of the car. Just a simple stock bar makes all the difference in the world. |
orange914 |
Dec 27 2007, 10:21 PM
The small reinforcement piece in the rear trunk for the rear bar is the usual giveaway that the car came equipped with bars. I'd got any pictures you could post on the rear bar reinforcement piece? (IMG:style_emoticons/default/poke.gif) mike |
Dec 27 2007, 11:41 PM
The tabs on the front A-arms were standard once the sway bars were an available option. So, why does my '70/4 have the tabs when the bars didn't become available 'till years later? Another 914 anomaly, perhaps? (IMG:style_emoticons/default/confused24.gif) |
Eric_Shea |
Dec 28 2007, 01:57 AM
I believe that Jason has started the great anti-sway bar debate. (IMG:style_emoticons/default/biggrin.gif)
In reading Paul's comment about the a-arms and seeing the obvious indent molded into the very first chassis blank (not to mention the indented ridge in the fuel tank), I would tend to think an anti-sway bar could have been checked off on an options list in 1970. I'm prone to being wrong however. Afterall I was 8-9 years old when the said checking off of the said list were to have taken place. Now that I'm older I lack the energy to look for said list and I rely on the collective wisdom of the 914World list, better known as Wolfgang, Geoff and Mr. Pateman. (IMG:style_emoticons/default/wink.gif) |
TedK |
Dec 28 2007, 12:59 PM
So, now for the big question..................if you are going to add bar(s), then what is best? Front only, both, and what size(s). Street use only.
Cheers Ted K |
Eric_Shea |
Dec 28 2007, 01:49 PM
I've done this and... for street use only I "highly" recommend both stock bars. You'll probably get all sorts of replies but a stock bar on a teener transforms it nicely.
914Sixer |
Dec 28 2007, 03:03 PM
In the 914-6 factory competition parts book dated March 1970, you could order a 11,13,14,15 mm front stabilzer bars for the front and 15,16 mm for the rear. They were the same front bars available for the 911's at that time. You would have to ask Dr914 if his M471 914-6 has bars from the factory. I would think you could order them on the competition cars.
Lo-Fi Version | Time is now: 7th May 2024 - 03:49 AM |
