Where is the best place to buy?, SDS EFI setup |
hcdmueller |
Dec 27 2007, 04:48 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I am finishing up a 2056 Kit from Jake and was going to go with carbs. I am having second thought on that. I know a lot about EFI and only a little about carbs. I want more (IMG:style_emoticons/default/driving.gif) and less (IMG:style_emoticons/default/smash.gif)
I like the reliability and simplicity of the carbs but I don't want to be messing with stuff once I get it set up. The question is where is the best place to buy an SDS EFI setup for fuel only? |
904svo |
Dec 27 2007, 05:59 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
From Jake!
Ask him to have it set up for you. |
lotus_65 |
Dec 27 2007, 06:01 PM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
hcdmueller |
Dec 27 2007, 06:15 PM
Jake took the EFI stuff off of his store. I seem to remember reading a post from him where he said he would only be doing a whole package setup with turnkey engines. I don't know. I will check out the LN Engineering link.
Thanks |
Ray Warren |
Dec 27 2007, 06:28 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
You could try this place.
Krieger |
Dec 27 2007, 10:37 PM
Advanced Member Group: Members Posts: 4,712 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Why not the stock d jet, it would work great for your set up?
ottox914 |
Dec 27 2007, 10:43 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Just go right to the source: www.sdsefi.com. Setting up fuel only would be a snap compaired to what I did to add the ignition control- not that it was that painful, but you could use the stock throttle body, injectors, and control it all with the SDS. I love mine. I think it has enough features to really get the job done well, but not so many options/screens/configurations to make it cumbersome and confusing to deal with.
Jake Raby |
Dec 28 2007, 02:10 PM
We will be re introducing the RAT/SDS EFI packages first of the year... we pulled the systems due to long delays in filling orders waiting on throttle bodies and injectors.
I have been working with SDS for the past 6 months or so on a new chip specifically for an aircooled applicatio that allows the AFR in closed loop to be set at a predetermined value, instead of stoich.. This seriously impacted the drivability of my 912E and the Pinzgauer that I have them set up on as test mules. The cool thing about it is the chip will auto correct for a 25% variance in RPM fuel or MP values to reach the target AFR and it responds very quickly when enabled. It gave me a solid 3MPG in the 912E and two MPG in the Pinz. This post has been edited by Jake Raby: Dec 28 2007, 02:12 PM |
Jake Raby |
Dec 28 2007, 02:14 PM
Porcharu |
Dec 28 2007, 03:18 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I got mine from SDS. Quick delivery fair price.
gregrobbins |
Dec 29 2007, 12:57 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
I'll be getting mine from Jake. I like the idea that he makes sure it is set up for the Type IV and combo I am running.
QUOTE All in the combo. |
Jake Raby |
Dec 29 2007, 01:41 PM
In most cases we have a very close fuel map that we can upload when testing the unit, prior to shipping..
Those that have my combinations benefit from this because I have a couple of maps for most of these combos from test engines, or customer's turn keys that we have tuned. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:48 AM |
