hcdmueller
Dec 27 2007, 04:48 PM
I am finishing up a 2056 Kit from Jake and was going to go with carbs. I am having second thought on that. I know a lot about EFI and only a little about carbs. I want more
and less
I like the reliability and simplicity of the carbs but I don't want to be messing with stuff once I get it set up.
The question is where is the best place to buy an SDS EFI setup for fuel only?
904svo
Dec 27 2007, 05:59 PM
From Jake!
Ask him to have it set up for you.
lotus_65
Dec 27 2007, 06:01 PM
i don't know if this is the best... but it's one place.
http://www.lnengineering.com/fi.html
hcdmueller
Dec 27 2007, 06:15 PM
Jake took the EFI stuff off of his store. I seem to remember reading a post from him where he said he would only be doing a whole package setup with turnkey engines. I don't know. I will check out the LN Engineering link.
Thanks
Ray Warren
Dec 27 2007, 06:28 PM
You could try
this place.
Krieger
Dec 27 2007, 10:37 PM
Why not the stock d jet, it would work great for your set up?
ottox914
Dec 27 2007, 10:43 PM
Just go right to the source: www.sdsefi.com. Setting up fuel only would be a snap compaired to what I did to add the ignition control- not that it was that painful, but you could use the stock throttle body, injectors, and control it all with the SDS. I love mine. I think it has enough features to really get the job done well, but not so many options/screens/configurations to make it cumbersome and confusing to deal with.
Jake Raby
Dec 28 2007, 02:10 PM
We will be re introducing the RAT/SDS EFI packages first of the year... we pulled the systems due to long delays in filling orders waiting on throttle bodies and injectors.
I have been working with SDS for the past 6 months or so on a new chip specifically for an aircooled applicatio that allows the AFR in closed loop to be set at a predetermined value, instead of stoich..
This seriously impacted the drivability of my 912E and the Pinzgauer that I have them set up on as test mules. The cool thing about it is the chip will auto correct for a 25% variance in RPM fuel or MP values to reach the target AFR and it responds very quickly when enabled.
It gave me a solid 3MPG in the 912E and two MPG in the Pinz.
Jake Raby
Dec 28 2007, 02:14 PM
QUOTE(Krieger914 @ Dec 27 2007, 09:37 PM)
No, his kit was set up for carbs specifically. The camshaft it includes is absilutely incompatible with stock FI.
Porcharu
Dec 28 2007, 03:18 PM
I got mine from SDS. Quick delivery fair price.
gregrobbins
Dec 29 2007, 12:57 PM
I'll be getting mine from Jake. I like the idea that he makes sure it is set up for the Type IV and combo I am running.
All in the combo.
Jake Raby
Dec 29 2007, 01:41 PM
In most cases we have a very close fuel map that we can upload when testing the unit, prior to shipping..
Those that have my combinations benefit from this because I have a couple of maps for most of these combos from test engines, or customer's turn keys that we have tuned.
