Spoke's 71 2.056L 914 Progress Thread, Driving it Like I Stole It |
Spoke |
Dec 28 2007, 10:59 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Like Zach said before, just what the World needs is another progress thread. So here it is for my 71 1.7L red ride.
I'm working on an engine swap for my leaky 1.7L with slipping clutch to a non-leaking, unknown GEX rebuilt 1.8L so I decided to concatenate several threads on this car into one progress thread. Eventually I will sell the red 71 and keep the green 74 as my only 914. For now the plan is to get the new 1.8L engine in the car. The 1.8L has SSHE where the 1.7L in the car has very much corroded stock HE's. Here's pics after last year's rear end accident that totaled the car and the finished product after many months of rehab. Attached image(s) |
FourBlades |
Sep 11 2009, 09:09 PM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Your car is really coming along. You jack tube sticks out because of the way your long was repaired. The stock metal is two layers thick where the tube goes through. The innermost layer bows into the long by an inch or more. The next layer is the outer long which is vertical and has a hole in it that the jack tube passes through. You either need to cut a hole in your long and stick the tube in and weld it or shorten the tube and weld it to your repaired long. This may be weaker than stock, if your repaired long is two layers of good metal it may work ok. A little hard to explain in words, if you look at some of the other rusto threads you can see what I mean. John |
Spoke |
Sep 11 2009, 09:20 PM
Your car is really coming along. You jack tube sticks out because of the way your long was repaired. The stock metal is two layers thick where the tube goes through. The innermost layer bows into the long by an inch or more. The next layer is the outer long which is vertical and has a hole in it that the jack tube passes through. You either need to cut a hole in your long and stick the tube in and weld it or shorten the tube and weld it to your repaired long. This may be weaker than stock, if your repaired long is two layers of good metal it may work ok. A little hard to explain in words, if you look at some of the other rusto threads you can see what I mean. John Thanks, I knew the repaired long wasn't that much fatter than stock. I think I will cut a hole then. If I shorten the tube, the jack may not seat all the way and could slip out. In my best Dwight Shrute voice: Question: How far does the tube stick out from the support? If I cut a hole and slide the tube in, then I need to know how far out the tube is from the support. I don't have a stock 914 to look at.......Who put my stapler in Jello? .....MICHAEL!!!! |
Lo-Fi Version | Time is now: 19th May 2024 - 02:31 AM |
