intake tune up |
intake tune up |
minnesota loon |
Jan 2 2008, 06:09 PM
Member Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
I would like to put new parts on the intake system. I also want to replace injector seals and want to paint intake tubes. Any suggestions? Any way to clean up the injectors?
PeeGreen 914 |
Jan 2 2008, 07:08 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Why do you need to do this? Are they leaking or not performing well?
You can take them out and have someone clean and reseal them. At our shop we send all of them to the injector doctor. When we get them back they are as good as new. |
jimkelly |
Jan 2 2008, 08:04 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
you could ...
send you injectors to http://www.witchhunter.com/ get new fuel hose elbows from http://www.trademotion.com/partlocator/index.cfm?siteid=26 # 16121176821 get hose clamps from http://www.busdepot.com/details.jsp?partnumber=311133515 Attached image(s) |
jesiv |
Jan 2 2008, 09:32 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
I just did this. I completely reparied and replaced the intake system. Checked the specs, replaced (if necessary), cleaned it up and painted (where necessary) each component. The end result... It purrs... and for a 1.8 that is saying something. If you car is not running as smooth as you like and you can't remember when you last inspected you complete intake system -- now is the time. It's cold all elements "cold start" etc are needed.
Regards, James |
DanT |
Jan 2 2008, 09:43 PM
runners bead blasted and painted in grey.
fuel rail cleaned and polished injectors cleaned and injector retainers wire wheeled and then painted black Attached image(s) |
DanT |
Jan 2 2008, 09:44 PM
and
Cap'n Krusty |
Jan 2 2008, 10:48 PM
Why do you need to do this? Are they leaking or not performing well? You can take them out and have someone clean and reseal them. At our shop we send all of them to the injector doctor. When we get them back they are as good as new. Uhhhhhhh, new injector seals can be easily installed by a 5 year old in the comfort of his parents' garage. How hard can it be to put on 2 rubber o-rings? The Cap'n |
Slider |
Jan 2 2008, 10:50 PM
Problems are like cockroaches you find 1 and theres a 100 more Group: Members Posts: 223 Joined: 11-March 07 From: Fort Collins Colorado Member No.: 7,591 Region Association: Rocky Mountains |
Automobile Atlanta has some paint that is suppose to match the original color of the intake runner if thats what your going for.
what about Powder Coating them? |
PeeGreen 914 |
Jan 2 2008, 11:03 PM
Why do you need to do this? Are they leaking or not performing well? You can take them out and have someone clean and reseal them. At our shop we send all of them to the injector doctor. When we get them back they are as good as new. Uhhhhhhh, new injector seals can be easily installed by a 5 year old in the comfort of his parents' garage. How hard can it be to put on 2 rubber o-rings? The Cap'n Yeah, but the guy just throws them on there after he has cleaned them and checked them to make sure they are okay. If the injectors are leaking due to seal we do that ourselves (IMG:style_emoticons/default/drunk.gif) |
minnesota loon |
Jan 4 2008, 05:22 PM
Thanks for the advice. I just want to put new parts in to update 30 year old plus parts. The painted engines look great thanks again.
Lo-Fi Version | Time is now: 19th May 2024 - 02:30 AM |
