OT: Problem with 968 door locks |
keske968 |
Jan 3 2008, 06:32 PM
Member Group: Members Posts: 132 Joined: 5-September 06 From: Papillion, Ne Member No.: 6,778 Region Association: None |
Don't know if any members here have a 968 but for some reason my passenger side door isn't unlocking with the key or the electric switch. It seems like it wants to come up but it just isn't. I'm looking for suggestions before I let the dealer take a crack at it.
Any ideas would be greatly appreicated. |
Brando |
Jan 4 2008, 02:19 PM
Take the door panel off. Common failure is the plastic arm that works the lock/unlock mechanism.
If the electrical part isn't working, it may be the microswitches in the lock/tumbler/handle, or an electrical fault. |
keske968 |
Jan 4 2008, 05:18 PM
Take the door panel off. Common failure is the plastic arm that works the lock/unlock mechanism. If the electrical part isn't working, it may be the microswitches in the lock/tumbler/handle, or an electrical fault. Took as much of the panel off as I could seeing as I cant get the door open. I am able to see where the plastic arm is but the thing is that its not moving at all. The metal plates that that move to lock the door are jammed somehow. The electric lock is trying to move it but there is something definitly jammed. Looks like when my next student loan check comes in the dealer will take a wack at it. Too bad my 914 won't be operational until this spring. |
jasons |
Jan 4 2008, 05:31 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Take the door panel off. Common failure is the plastic arm that works the lock/unlock mechanism. If the electrical part isn't working, it may be the microswitches in the lock/tumbler/handle, or an electrical fault. (IMG:style_emoticons/default/agree.gif) 110% Had both break on my 944S2 See #2 in this parts diagram http://www.pelicanparts.com/cgi-bin/PartsL...mp;Line_Item=10 EDIT: just re-read your "plates jammed" problem. I would look again, these plastic things break all the time. |
jasons |
Jan 4 2008, 05:41 PM
Actually, the more I think about it, if the lock is "trying" to come up then the rod couldn't be broken.
(IMG:style_emoticons/default/blink.gif) |
Brando |
Jan 4 2008, 07:52 PM
The rod I was talking about was the plastic piece - they're notorious for breaking when it starts to take more and more force to unlock the door. (PN 944-537-511-00).
It would be best if you took the door panel and plastic covering off of the door and looked/felt around for where the bind is, if the plastic rod isn't the culprit. Other than that, without taking a look for myself, I would guess it to be a mechanical failure in the lock mechanism itself. (PN 928 537 053 09). Hope that helps. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:11 AM |
