QUOTE(Brando @ Jan 4 2008, 02:19 PM)
Take the door panel off. Common failure is the plastic arm that works the lock/unlock mechanism.
If the electrical part isn't working, it may be the microswitches in the lock/tumbler/handle, or an electrical fault.
Took as much of the panel off as I could seeing as I cant get the door open. I am able to see where the plastic arm is but the thing is that its not moving at all. The metal plates that that move to lock the door are jammed somehow. The electric lock is trying to move it but there is something definitly jammed. Looks like when my next student loan check comes in the dealer will take a wack at it. Too bad my 914 won't be operational until this spring.
