best product for degreasing..., caked-on poo. |
slackin' at work |
Jan 4 2008, 10:00 AM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
The previous owner didn't worry too much about leaks. Ive replaced pushrod tube
seals and cover gaskets. nice and dry now. I have SS exchangers... but the years of leaks have left there mark. the engine is fairly clean but it's the heat exchangers which are nasty from the top-end leaks. Before I put the rest of the ductwork for the heat back on the car I want/need to clean both the inside and outside of the exchangers. If I don't Im forever going to be poisoned by the burning remnants of oil. yuck. without removing them, what is the best way to get them nice and de-greased? any products work better than other? thanks! -chris |
SGB |
Jan 4 2008, 10:15 AM
Simple Grreen seems to work as well as a solvent based degreaser, IMO.
Bartlett 914 |
Jan 4 2008, 10:29 AM
I have good luck using pressure washer concentrate. I use the Pink formula from Generac. I put it in a spray bottle and use it direct. Sometimes too strong. Be careful on Fiberglass and some painted surfaces. I don't let it dry. Really cuts grease and dirt. Solvent cleaners often get grease but not dirt.
Jax914 |
Jan 4 2008, 11:23 AM
Schwienhund Rennenmannshaft Group: Members Posts: 138 Joined: 7-August 06 From: Jacksonville, FL Member No.: 6,602 Region Association: South East States |
Easy Off Oven Degreaser worked amazingly. RESIST the urge to scrape with anything more than a plastic scrub brush. You may need to do a couple of application cycles, but it will work and will not damage the stainless.
HTH, |
smontanaro |
Jan 4 2008, 11:54 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Couldn't you just take your heat exchangers to a machine shop and have them cooked in the hot tank?
Skip |
jaminM3 |
Jan 4 2008, 11:58 AM
Member Group: Members Posts: 418 Joined: 23-March 07 From: SLC, UT Member No.: 7,619 Region Association: Intermountain Region |
I think to do it right you have to take them off the car, especially if you want to clean the inside too. Just go to a pressure wand car wash and bring a can of engine degreaser. I couldn't find a shop that would let me put a trans case in the hot tank, so I did that and got great results (IMG:style_emoticons/default/thumb3d.gif) |
MrKona |
Jan 4 2008, 11:59 AM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
Easy off oven cleaner worked for me. Several applications, light application of some extra fine steel wool in the tough spots, and finish it off with Mother's metal polish.
slackin' at work |
Jan 4 2008, 12:24 PM
Couldn't you just take your heat exchangers to a machine shop and have them cooked in the hot tank? what other kind of places would have a hot tank? we have no machine shops local. (It is central VA (IMG:style_emoticons/default/dry.gif) ). is this another name for a parts washer... or something totally different? I was hoping to keep them on, but I agree that getting inside with them on my be a no-go. |
Jan 4 2008, 12:38 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
brake cleaner ... (IMG:style_emoticons/default/thumb3d.gif)
just make sure you're in a well ventilated area ... (IMG:style_emoticons/default/icon8.gif) Andy |
stateofidleness |
Jan 4 2008, 05:49 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
going along with the cleaning part
whats the best way to clean the engine and tranny case without damaging anything or getting into heavy dismantling? is it safe to power wash? solvent? parts to avoid? |
Tom |
Jan 5 2008, 12:36 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
When I had my engine out for sealing and cleaning, I used a dawn product. I think it was called "power degreaser". Comes in a dark blue spray bottle and is kind of a gel type cleaner. Worked outstanding. Did require some re-application and mild scrubbing with a parts cleaner brush. Make sure you wear gloves tho'. Made the aluminum shine like new. Only used cold water to rinse, so if hot water is available it would be even better. Oh, be careful of getting it on paint. It will damage the paint.
Tom |
Jan 5 2008, 01:01 AM
whats the best way to clean the engine and tranny case without damaging anything or getting into heavy dismantling? brake cleaner ... (IMG:style_emoticons/default/shades.gif) Andy |
smokey |
Jan 5 2008, 01:17 AM
Senior Member Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None |
bigkensteele |
Jan 5 2008, 01:46 AM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
whats the best way to clean the engine and tranny case without damaging anything or getting into heavy dismantling? brake cleaner ... (IMG:style_emoticons/default/shades.gif) Andy By my estimation, this is the 63rd post where Andy has recommended brake cleaner for somthing. If I recall correctly, he even likes it on toast and in his coffee. (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/poke.gif) |
PeeGreen 914 |
Jan 5 2008, 01:52 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Hey... the stuff works well. At the shop I use to wrench at that was the #1 degreaser. It cuts through everything including paint. (IMG:style_emoticons/default/piratenanner.gif) Really don't know of anything better to use without taking it out of the car. Just don't get high off the stuff. It smells nasty.
chris914 |
Jan 5 2008, 03:42 AM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I use mineral spirits and a wire brush. It’s cheap and washes off with water. I put the mineral spirits in a squirt bottle. Then I rise with Simple Green. I also use a hose connected to the hot water from the sink in the garage. It is amazing how much the hot water makes a difference.
stateofidleness |
Jan 5 2008, 08:42 AM
the engine is out, was just wondering what people's approaches were to shiny new metal
brake cleaner eh? use a lot? use sparingly? will have to give that a try when i get home |
Gint |
Jan 5 2008, 09:54 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
whats the best way to clean the engine and tranny case without damaging anything or getting into heavy dismantling? brake cleaner ... (IMG:style_emoticons/default/shades.gif) Andy I buy brake cleaner by the case... |
John |
Jan 5 2008, 10:13 AM
Brake cleaner is great. I use it quite a bit for most everything, but I believe that there are some better products out there (cheaper).
I use Super Agitine in my 30 gal parts washer. I use Castrol Super Clean in a 5 gal bucket as well. This stuff is real bad for skin and if left in, it will badly damage aluminum, but it takes burnt on oil and grease off better than brake cleaner. I also use Dawn liquid dish soap in HOT water. That works well on a budget. At $3.00+ a can, brake cleaner can get expensive, so I have found a few alternatives. I have used the Super Clean and Purple Power in a power washer and they do work well with HOT water (I have both hot and cold water faucets on the outside of my garage.) |
TINCAN914 |
Jan 5 2008, 10:18 AM
Summer's Commin... Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains |
whats the best way to clean the engine and tranny case without damaging anything or getting into heavy dismantling? brake cleaner ... (IMG:style_emoticons/default/shades.gif) Andy I buy brake cleaner by the case... Has worked best for me as well, just be careful of painted surfaces. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 04:30 AM |
