New Master Cylinder-getting the lines in, how to get the resivour fittings in! |
7391420 |
Jan 5 2004, 03:13 PM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
All right guys,
I am almost done with replacing my master cylinder, the old one was a bitch to get out considering 30 years of east coast grime, but it came out without breaking or striping anything. now, to get the new one in, whats the best way to get the metal resivour lines to seat in the rubber boots! everything else lines up fine, but no matter how hard I push and pull, I cant get the lines to fit all the way in! I have read the article on the Pelican site and have tried the recomendations there, so now I'm asking the true pro's! Help!! -Adam |
Mueller |
Jan 5 2004, 03:19 PM
loosen the fittings at the reservoir on top, pull the two lines down from under the car as far as you can (normally 4 or 5 inches further than they normally are)
I put the rubber grommets in the M/C first, then I lube the lines up with some clean brake fluid and twist the lines in........ this is with the hard lines disconnected. |
7391420 |
Jan 5 2004, 03:24 PM
Mike,
Thanks for the help, I'll try this out tonight, I think that I was worried that I would pull the resiv. lines out if I pulled them down to far, but 4-5 inches should be enough to get in and secure them yet still be able to attach the brake line fittings. -Adam |
scotty |
Jan 5 2004, 06:20 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
...twist and push hard! You should hear/feel a positive *snick* when they pop in.
jimkelly |
Dec 22 2012, 07:29 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
pics - as i need to install a MC soon
sixaddict |
Dec 22 2012, 08:10 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
This job is a beotch! I got so frustrated I took it to the shop and let them finish it.....very simple to describe how but pain to execute unless on a lift. (IMG:style_emoticons/default/headbang.gif)
timothy_nd28 |
Dec 22 2012, 08:51 PM
Before I put the rubber grommets into the MC, I lightly grease the inside grommets then install them into the MC. Then I lightly grease the res brake lines. After all that, push and twist the lines into the MC. They pop in pretty easy, when all greased up.
jimkelly |
Dec 23 2012, 06:56 AM
seems like removing lines from reservior is the way to go.
i'll be on jack stands. seems simple enough? Attached image(s) |
jimkelly |
Dec 23 2012, 07:30 AM
i removed reserve lines - and yes - pressing them into MC requires less pressure - not more - and i did put a drop of brake fluid in the gromet to slip things up.
don't forget to put washers under gromets. need to get some 8mm fuel line to replace the short peices of dry rotted braided line that connects the 8mm feed lines from the MC to reservoir. BTW - the lines are metal at bottom 20% and plastic at top 80% - line fuel lines. Attached image(s) |
PanelBilly |
Dec 23 2012, 01:38 PM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I thought I'd never get these seated. Lube it up with brake fluid and swear a lot.
type47 |
Dec 25 2012, 08:59 AM
Lo-Fi Version | Time is now: 8th May 2024 - 08:46 PM |
