BMXerror |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 ![]() |
Well, how does the sizing standard for rings work? How do I know which size to get for my teener? Also, are the top and second rings exactly the same, or is there some 'invisible' difference between the two? Thanks.
Mark D. |
BMXerror |
Okay, when I wrote that original post, I was REALLY tired, so it probably doesn't make any sense. What I'm really asking is; when you go to order rings, they give you four numbers, like 90 x 2 x 2 x 5. 90 is obviously the cylinder bore, but what do the other three stand for. I'm guessing one is ring height and one is ring thickness (Inward towards the center of the piston), but I don't really know for sure. Please, help. Thanks.
Mark D. P.S. Before you say so, I have searched on the internet for the answer before asking for help. I haven't been successful, even on one website call the 'Ring Museum', I didn't find my answer. |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
Okay, when I wrote that original post, I was REALLY tired, so it probably doesn't make any sense. What I'm really asking is; when you go to order rings, they give you four numbers, like 90 x 2 x 2 x 5. 90 is obviously the cylinder bore, but what do the other three stand for. I'm guessing one is ring height and one is ring thickness (Inward towards the center of the piston), but I don't really know for sure. Please, help. Thanks. Mark D. P.S. Before you say so, I have searched on the internet for the answer before asking for help. I haven't been successful, even on one website call the 'Ring Museum', I didn't find my answer. i just went through this... arrrgh..., what pistons do you have? 90 would be bore 2 top ring thickness 2 second ring 5.90 oil ring from what i found there were 2 ring sets for 96mm (i'm no final athority here!) 96x1.5x2x6 & 96x2x2x6 the limited research i did i read the thinner rings gave less drag but not as durable hope this helps mike |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The thinner rings are for pistons with narrower grooves. Use a thin ring in a wide-groove piston, and the few miles you get before the ring breaks and tears up the piston and the cylinder won't be worth the time it took you do do the job. Again.
The Cap'n |
Lo-Fi Version | Time is now: 1st July 2025 - 01:28 AM |
