Please Help this tune up is kicking my a** |
WizPorsche914 |
Jan 9 2008, 02:00 PM
Member Group: Members Posts: 128 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region |
Everything on this 72 914 is orignal, Im trying to replace the coil, cap, rotor wires and plugs with hopes of it running a little better ( it runs but not too well). How in the world do thouse dam little clips on the cap slide back into place ? Ive been trying for a solid hour to get them back on.
Also the plug what should I set them at ? |
Dr Evil |
Jan 9 2008, 03:42 PM
You are only about 1hr from me, its good to see another local guy. If the clips wont go in then your cap may be 180 out. I forget what the plugs are set at, but I know it is in the Haines manual if you have one ( you should get one if you dont). Have you checked the dwell on your points? Have you checked the condition of your points? When you say it is running poorly, what are the symptoms? |
So.Cal.914 |
Jan 9 2008, 04:03 PM
(IMG:style_emoticons/default/welcome.png) You are only about 1hr from me, its good to see another local guy. If the clips wont go in then your cap may be 180 out. I forget what the plugs are set at, but I know it is in the Haines manual if you have one ( you should get one if you dont). Have you checked the dwell on your points? Have you checked the condition of your points? When you say it is running poorly, what are the symptoms? Like Evil said your dizzy has a notch on top that accepts its mate on the cap. Check and see if is seated correctly. Eather that or maybe something else is getting in the way. If not push on them harder. (IMG:style_emoticons/default/smile.gif) |
WizPorsche914 |
Jan 9 2008, 04:37 PM
When it idles it wants to stall out. What should points be set at and how are they installed ? This is my first car with points. I own a 944 also.
Rand |
Jan 9 2008, 04:53 PM
Regarding the clips on the distributor cap.... Sometimes it is helpful to tip the cap a little towards one side and get that clip on, then push the cap down into position and snap the other clip on.
Lo-Fi Version | Time is now: 17th May 2024 - 07:37 PM |
