Pics of my engine build, by member request |
DanT |
Jan 10 2008, 12:23 AM
here we go
PeeGreen 914 |
Jan 10 2008, 12:39 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
Oh suuuuuure... You just wanted to show off again (IMG:style_emoticons/default/happy11.gif) Not that I can complain (IMG:style_emoticons/default/drooley.gif) . That looks sooooo nice.
DanT |
Jan 10 2008, 12:41 AM
No really...."Stateofidleness" PMed me asking for some pics...
but I do like to show off my little home built 2056 (IMG:style_emoticons/default/biggrin.gif) |
Nor.Cal.914 |
Jan 10 2008, 04:04 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
Is that a deep sump kit?
yarin |
Jan 10 2008, 04:27 PM
'14-X'in FOOL Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States |
orange914 |
Jan 10 2008, 06:16 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Is that a deep sump kit? Tuna can. Get's the job done as long as you don't try to drive it into a sidewalk or rock. Most track guys prefer some type of extended pickup / oil starvation solution. there should be no issues installing that tuna can on the engine when it's in the car, is there? mike |
DanT |
Jan 10 2008, 07:26 PM
Is that a deep sump kit? Tuna can. Get's the job done as long as you don't try to drive it into a sidewalk or rock. Most track guys prefer some type of extended pickup / oil starvation solution. there should be no issues installing that tuna can on the engine when it's in the car, is there? mike Nope |
McMark |
Jan 11 2008, 12:30 PM
The tuna can is higher than the mount bar. So if you hit your tuna can, you've got bigger problems. (IMG:style_emoticons/default/happy11.gif)
DanT |
Jan 11 2008, 12:59 PM
The tuna can is higher than the mount bar. So if you hit your tuna can, you've got bigger problems. (IMG:style_emoticons/default/happy11.gif) exactly...even my headers hang down lower than the tuna can. (IMG:style_emoticons/default/smile.gif) here is a pic of the motor before the rebuild....yucky as you can see the headers and the motor bar are lower than the tuna can....yes it is in there. (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Chris Pincetich |
Jan 11 2008, 01:06 PM
The bolt that runs down the middle of the tuna can can destroy your engine case if it is over-torqued (spec is <10lbs), so use new crush washers and be carefull!
Also, the pick-up tube is sometimes too long, so it must be grinded to fit...again, be carefull during instal. (IMG:style_emoticons/default/beerchug.gif) Orange you glad you asked? (IMG:style_emoticons/default/biggrin.gif) |
DanT |
Jan 11 2008, 01:23 PM
the pickup being too long happened several years ago, they had a batch that got machined too long...
All of the newer ones I have seen are the correct length. Chris is right, be careful about how much torque you put on the center bolt. |
orange914 |
Jan 11 2008, 11:35 PM
The bolt that runs down the middle of the tuna can can destroy your engine case if it is over-torqued (spec is <10lbs), so use new crush washers and be carefull! Also, the pick-up tube is sometimes too long, so it must be grinded to fit...again, be carefull during instal. (IMG:style_emoticons/default/beerchug.gif) Orange you glad you asked? (IMG:style_emoticons/default/biggrin.gif) well... the only dumb question is the one not asked, but... i've been told that doesnt hold true for me (IMG:style_emoticons/default/biggrin.gif) how did you check for clearance of oil pick-up length? is the pick up an extention, what does it look like thanks, mike |
DanT |
Jan 11 2008, 11:41 PM
the oil pickups were too long and the "can" would not seat and seal properly.
It is a matter of feel when you put it all together...placing everything together and then making sure the can is sitting flush before tightening the center bolt. don't have a pic of the actual pickup |
McMark |
Jan 12 2008, 12:48 AM
stateofidleness |
Jan 12 2008, 01:42 AM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
thank you so much sir
ill post some pics of my 2.0L and maybe you can help me out with stuff that looks "out of place" on it? |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 PM |
