QUOTE(ChrisNPDrider @ Jan 11 2008, 11:06 AM)
The bolt that runs down the middle of the tuna can can destroy your engine case if it is over-torqued (spec is <10lbs), so use new crush washers and be carefull!
Also, the pick-up tube is sometimes too long, so it must be grinded to fit...again, be carefull during instal.
Orange you glad you asked?
well...
the only dumb question is the one not asked, but...
i've been told that doesnt hold true for me
how did you check for clearance of oil pick-up length? is the pick up an extention, what does it look like
thanks, mike
