914 901 Gear Ratios, Tech Article, Gear Ratio Workbook, Member Gear Set Library |
race914 |
Jan 14 2008, 10:44 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
To maximize my 914's performance on the track, I've put together several different gear sets for my 901. This has helped me to maximize my top speed on the straights, as well as acceleration out of the corners. This has proved to be a great advantage over stock geared 914s.
I want share the info I’ve collected, as well as what I’ve learned from these projects. I’ve put together a Gear Ratio Tech Article that includes: why you might consider re-gearing; ways to approach this project; the 914 901 Gear Ratio Workbook (MS Excel required); and references to 914World members that provide related products & services. Lastly, and perhaps most importantly, I’ll be maintaining the Member Gear Set Library that includes the various gear ratio setups that Members are using for different applications & situations. This centralized repository will greatly facilitate finding information applicable to your re-gearing project. Important Note! The ‘right’ gear set for you is particular to many factors. To list a few, the car’s weight, suspension, engine, and DRIVER! Don’t take the gear-sets listed for a particular application as your ideal setup. Contact the owner, compare corner speeds, suspension setups, engine characteristics, driving skills, etc. All of these factors play into what will work for you. If you'd like to contribute to the "Member Gear Set library", post your info on this thread and include: * Applicable Category (Autocross, Street, Track (including track name) * Engine (cc & cylinders), * HP, * Redline RPM, * Tire Diameter, * Weight w/driver, * 1st-5th gear codes, and * Any short comment that you’d like to pass on, or better yet, a link to the applicable 914World discussion thread on your setup |
naro914 |
Aug 1 2010, 07:40 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I basically did what's in the link above 'to achieve a taller 5th'.
Stock was A F N V ZD Flipped 5th to 3rd, and 3rd to 5th, and swapped V 4th to R, I now have: A F KA R Z It's a real cheap way to bring all the ratio's down for MUCH better acceleration, only have to buy 4th. When someone asks, I say it feels like I have a 2 1/2, 3 1/2 and 4 1/2 gear, not 3, 4 and 5. So: * Applicable Category - Track * Engine - 2.2 liter 6 cyl * HP - approx 200 * Redline RPM - 7400 * Tire Diameter - don't know? * Weight w/driver - 2000 * 1st-5th gear codes, - A F KA R Z Works great at CMP, VIR, Barber, Watkins Glen. Not so great for Road Atlanta - could use a taller 5th. |
tomburdge |
Aug 11 2010, 02:18 PM
Newbie Group: Members Posts: 33 Joined: 11-August 05 From: Hillsborough,N.J. Member No.: 4,576 |
I basically did what's in the link above 'to achieve a taller 5th'. Stock was A F N V ZD Flipped 5th to 3rd, and 3rd to 5th, and swapped V 4th to R, I now have: A F KA R Z It's a real cheap way to bring all the ratio's down for MUCH better acceleration, only have to buy 4th. When someone asks, I say it feels like I have a 2 1/2, 3 1/2 and 4 1/2 gear, not 3, 4 and 5. So: * Applicable Category - Track * Engine - 2.2 liter 6 cyl * HP - approx 200 * Redline RPM - 7400 * Tire Diameter - don't know? * Weight w/driver - 2000 * 1st-5th gear codes, - A F KA R Z Works great at CMP, VIR, Barber, Watkins Glen. Not so great for Road Atlanta - could use a taller 5th. Doesn't get much taller then a ZD, does it? I've got one if you need it. Tom B. |
naro914 |
Aug 11 2010, 03:39 PM
Lo-Fi Version | Time is now: 21st May 2024 - 03:54 PM |
