914 901 Gear Ratios, Tech Article, Gear Ratio Workbook, Member Gear Set Library |
race914 |
Jan 14 2008, 10:44 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
To maximize my 914's performance on the track, I've put together several different gear sets for my 901. This has helped me to maximize my top speed on the straights, as well as acceleration out of the corners. This has proved to be a great advantage over stock geared 914s.
I want share the info I’ve collected, as well as what I’ve learned from these projects. I’ve put together a Gear Ratio Tech Article that includes: why you might consider re-gearing; ways to approach this project; the 914 901 Gear Ratio Workbook (MS Excel required); and references to 914World members that provide related products & services. Lastly, and perhaps most importantly, I’ll be maintaining the Member Gear Set Library that includes the various gear ratio setups that Members are using for different applications & situations. This centralized repository will greatly facilitate finding information applicable to your re-gearing project. Important Note! The ‘right’ gear set for you is particular to many factors. To list a few, the car’s weight, suspension, engine, and DRIVER! Don’t take the gear-sets listed for a particular application as your ideal setup. Contact the owner, compare corner speeds, suspension setups, engine characteristics, driving skills, etc. All of these factors play into what will work for you. If you'd like to contribute to the "Member Gear Set library", post your info on this thread and include: * Applicable Category (Autocross, Street, Track (including track name) * Engine (cc & cylinders), * HP, * Redline RPM, * Tire Diameter, * Weight w/driver, * 1st-5th gear codes, and * Any short comment that you’d like to pass on, or better yet, a link to the applicable 914World discussion thread on your setup |
brant |
Aug 17 2010, 03:52 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I am blown away with how versatile my ratio's are
my 5th is too high for the little tracks around here but will be great for big tracks I never find a hairpin that I can't use either my 1st or 2nd gear in. F - 1st J - 2nd O - 3rd S - 4th V - 5th seriously its a lot of work to put into a box but then you have a box that will do nearly any track it sure makes tow's to other states and first time visits to new tracks a lot more reassuring! brant |
bam914 |
Aug 18 2010, 08:48 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
I am blown away with how versatile my ratio's are my 5th is too high for the little tracks around here but will be great for big tracks I never find a hairpin that I can't use either my 1st or 2nd gear in. F - 1st J - 2nd O - 3rd S - 4th V - 5th seriously its a lot of work to put into a box but then you have a box that will do nearly any track it sure makes tow's to other states and first time visits to new tracks a lot more reassuring! brant Do you have reverse with the F 1st? I just bought a JNSX for my 914. |
Lo-Fi Version | Time is now: 21st May 2024 - 09:00 PM |
