914 901 Gear Ratios, Tech Article, Gear Ratio Workbook, Member Gear Set Library |
race914 |
Jan 14 2008, 10:44 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
To maximize my 914's performance on the track, I've put together several different gear sets for my 901. This has helped me to maximize my top speed on the straights, as well as acceleration out of the corners. This has proved to be a great advantage over stock geared 914s.
I want share the info I’ve collected, as well as what I’ve learned from these projects. I’ve put together a Gear Ratio Tech Article that includes: why you might consider re-gearing; ways to approach this project; the 914 901 Gear Ratio Workbook (MS Excel required); and references to 914World members that provide related products & services. Lastly, and perhaps most importantly, I’ll be maintaining the Member Gear Set Library that includes the various gear ratio setups that Members are using for different applications & situations. This centralized repository will greatly facilitate finding information applicable to your re-gearing project. Important Note! The ‘right’ gear set for you is particular to many factors. To list a few, the car’s weight, suspension, engine, and DRIVER! Don’t take the gear-sets listed for a particular application as your ideal setup. Contact the owner, compare corner speeds, suspension setups, engine characteristics, driving skills, etc. All of these factors play into what will work for you. If you'd like to contribute to the "Member Gear Set library", post your info on this thread and include: * Applicable Category (Autocross, Street, Track (including track name) * Engine (cc & cylinders), * HP, * Redline RPM, * Tire Diameter, * Weight w/driver, * 1st-5th gear codes, and * Any short comment that you’d like to pass on, or better yet, a link to the applicable 914World discussion thread on your setup |
HAM Inc |
Jan 19 2008, 09:03 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Scott how did you get a GA first? Also are you using a 904 mainshaft? If I understand correctly you can use any 2nd through 5th gear in any position on a 904 shaft. Correct?
Len |
stownsen914 |
Jan 19 2008, 02:39 PM
Scott how did you get a GA first? Also are you using a 904 mainshaft? If I understand correctly you can use any 2nd through 5th gear in any position on a 904 shaft. Correct? Len Len, The way I did it was to: 1. Take the fixed gear from a stock first gearset, and turn it down on a lathe to knock off the teeth. 2. Sacrifice a GA mainshaft by cutting the shaft off. Then bore a hole in the gear just large enough so it can be pressed onto the turned-down first gear from #1 above. 3. TIG weld the assembly. 4. The standard non-fixed gear from the GA gearset just plops right into place without mods. Note that you don't get reverse when you do this mod, since there is no matching reverse idler gear. Ideally I could have annealed the gears before welding and then re-heat treated, but I did not have that done. The gearset held up OK, though I recently had a bearing plate warp and a mainshaft bearing go bad in my trans. Could be due to use of first gear on the track, since that is a weak spot in the 901? The GA first does make for a killer close ratio gearbox though ... I have heard that another way to accomplish all this is to use a GA second gearset from a 904 mainshaft. You can have an adapter made to match the larger 904 second gear internal splines to the first gear splines. Scott |
Lo-Fi Version | Time is now: 21st May 2024 - 11:16 AM |
