911 Gauge Question & 914 Conversion |
computers4kids |
Jan 15 2008, 09:38 AM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
I bought a Getty Dash and am looking to fill the gauge pods & need some direction. What would be a fair price for an entire cluster of 911 gauges? I would still have to modify some of the gauges...see pic? I have an excellent 914 tach and speedometer so I can re-use them if need be. It seems after looking around, buying the gauges seperately end-up running the same or more than what I can pick-up an entire cluster for??? What is your wisdom on this subject? Attached image(s) |
marks914 |
Jan 15 2008, 10:16 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I have been quoted $400 for a set of cores, but you can usually get a set on ebay for $100-$150.
The 911 fuel gauge will work, the 914 fuel gauge back is a different size than the 911. The tach will work only on 6 cyl. engines. I am doing a set of these right now for a customer's V8 car. Mark Anyone know how to take the hands off of an early 911 clock? |
Aaron Cox |
Jan 15 2008, 10:55 AM
i pay about a 100 per set.....
mark covered the rest basically. tach is for a 6 cyl,, fuel gauge will work, you can get the oil pressure and temperature senders from a 911 that will fit the taco plate AND the oil pressure port on the case by the oil cooler.... clock - |
736conver |
Jan 15 2008, 11:44 AM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
100 to 150 is a good deal on good gauges. Later gauges or should I say earlier gauges 86 and up are usually more expensive.
Sometime you can aquire the gauges seperate for cheap. The one that usually get expenisvie is the combo gauge; oil pressure/temp. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:11 PM |
