Dave Hunt's 2270 on SDS.. First pull on the dyno, Dave is back at Aircooled Heaven! |
davep |
Jan 20 2008, 09:03 AM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Sensor leads may benefit from using a braided steel sleeve that is grounded at one end. The sleeve acts as a Faraday shield to help keep the leads from acting as a radio antenna and picking up stray voltages (interference) from a noisy environment. I use this all the time for thermocouple leads in my lab.
DNHunt |
Jan 20 2008, 09:25 AM
Yep, It ran with the CHT in close proximity to the lead to #3 so I suspect that it will be fine. I'll loop the sparp plug wires around the back of the tin and approach the plug to #3 from below and outboard of the plug. I'll lead the CHT up and slightly back so it'll be at closest approach about 3" .
The really critical leads in the harness are already sheilded and the sheild is grounded at The ECU. Dave |
DNHunt |
Jan 25 2008, 05:56 PM
It seems I have a crate down at the local FedEx Freight depot. It looks like my engine made it from Georgia to Washington in 5 days. That's hauling ass I think in the winter.
Dave |
Chris Pincetich |
Jan 25 2008, 07:06 PM
Cool, it hauls ass and it isn't even in the car yet! (IMG:style_emoticons/default/av-943.gif)
I'm waiting on some 914 race parts to show, and still waiting, and waiting...hoping to work on it this weekend (IMG:style_emoticons/default/beerchug.gif) |
rebelmdot |
Jan 25 2008, 10:13 PM
914ini Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States |
Now that Dave's engine is fantastic, I should introduce myself. I will be your next patient!!
Congratulations to you both, it seems like a lot of hard work was put in to make yet another IV scream. |
Jake Raby |
Jan 26 2008, 12:51 AM
Now if Dave's curse doesn't come back we'll be fine....
BTW- Based on what we saw this week in the lab we may have a 200 HP 2056 before a 200 HP production grade 2270.... |
rhodyguy |
Jan 26 2008, 08:25 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
wow!! fast is right. i'm fairly sure they are open today until 11:30 am in fife.
DNHunt |
Jan 26 2008, 10:04 AM
All done Kevin, it's at home in the garage. I couldn't pass up the dry weather so I went down about 7:30 and got it. They were also treatening storage fees. It looks like it shipped fine. I've got a big cleanup up in the shop, but I hope by Sunday night to have on a dolly. I can't see getting it in the car for another month or so.
Dave |
rhodyguy |
Jan 26 2008, 10:50 AM
a month...right...i've known you too long. you'll be lying in bed @ 3:30 am staring at the ceiling and by 3:45 you'll be out in the shop. (IMG:style_emoticons/default/biggrin.gif)
k |
effutuo101 |
Jan 26 2008, 10:57 AM
Advanced Member Group: Members Posts: 2,735 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Right on Dave! I can't wait to hear it run! I bet you are out cleaning the garage now. You have the patience of a saint if you can wait for 30 days without at least putting it in the car. (IMG:style_emoticons/default/biggrin.gif)
BMXerror |
Jan 26 2008, 03:06 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Made a partial run with added timing, lost power and gained CHT.. Now we are going the other direction with a 2 degree timing reduction.. AFR- RPM fuel values are done :-) After this verification pull it's time to play with variables like oil, fans and etc... What are the AFR's and timing curves I ALWAYS target 13:1 If we post the timing curves someone else will try to use them and may harm their engine, without this cam, CR and set of heads these won't do anyone any good.. What CR is this engine running? Mark D. |
DNHunt |
Jan 26 2008, 09:28 PM
In the neighborhood of 9.8:1
Dave |
Zimms |
Jan 27 2008, 08:48 AM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
BMXerror |
Jan 27 2008, 12:09 PM
seanery |
Oct 1 2018, 09:55 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Lo-Fi Version | Time is now: 7th June 2024 - 08:45 AM |
