More /6 piston and cylinder questions, Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhh! |
Dr Evil |
Jan 19 2008, 07:04 PM
OK, so now the question is, what piston do I need? The other 5 original cylinders to the engine say KS, are alusil, are height group 6 and size 0. The one that broke, and was from a different set, was a Mahle piston with a mahle cylinder. this is causing me issues as I do not know what compression ratio piston I need for my 1973.5 2.7L US engine. The two that this one guy is offering me are 90202 or 90208. Which should I take? He also said that a 1973.5 /6 was a 2.4 CIS engine. I think that is incorrect as I have never seen such a beast. MFI yes, CIS no.
sixnotfour |
Jan 19 2008, 07:36 PM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE 1973.5 /6 was a 2.4 CIS true statement |
Dr Evil |
Jan 19 2008, 07:40 PM
Lernt something today. I am pretty sure it is a 2.7, though and I still need the answer to my question about what piston to get from him. Any ideas, Jeff?
sixnotfour |
Jan 19 2008, 07:50 PM
90208 KS 2.7
Dr Evil |
Jan 19 2008, 07:51 PM
As always, thanks for your continued help (IMG:style_emoticons/default/biggrin.gif) You da man (IMG:style_emoticons/default/thumb3d.gif)
degreeoff |
Jan 19 2008, 07:59 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
Hey Mike,
The 73.5 WAS a 2.4...I have one and it is a 2.4....it also has the 7R case (hence why I bought it).... |
Dr Evil |
Jan 19 2008, 08:19 PM
2.4 WITH CIS? I know that the 2.7 started in 74, I got this engine from a 74, but some of the CIS bits are the earlier bits and why I think it is an early 2.7.
sixnotfour |
Jan 19 2008, 08:31 PM
73 had a split between MFI and CIS for the T model, hence 73.5 CIS 2.4
they had steel runner tubes |
Dr Evil |
Jan 19 2008, 08:35 PM
Ah, I have the cast aluminum tubes. I do have an extra setup with the steel tubes.
alpha434 |
Jan 19 2008, 08:36 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Another thread based on speculation.
It's not very important whether 73.5 was a 2.4 CIS if you have a cluster-fuched 2.7. Measure those things. If you hurry, and you have no calipers, you can buy some from FLAPs before they close. GO GO GO! |
Dr Evil |
Jan 19 2008, 08:37 PM
Feel free not to respond to my threads, alfalfa. (IMG:style_emoticons/default/dry.gif)
Dr Evil |
Jan 19 2008, 08:39 PM
What size were the jugs on the 2.4? I know I have 90mm which are the 2.7 so I am not worried about that. I was just wondering if I had the right CIS as well.
sixnotfour |
Jan 19 2008, 08:41 PM
check the PN on the fuel distributor.
Dr Evil |
Jan 19 2008, 08:43 PM
The p/n is right. I found the size for 2.4 as well, 86mm.
sixnotfour |
Jan 19 2008, 08:53 PM
84mm
Dr Evil |
Jan 19 2008, 09:03 PM
Strike!
Hey Jeff, would I be correct in thinking that the number you recommended is the lower CR 8:1 74 2.7 piston? |
sixnotfour |
Jan 19 2008, 09:22 PM
Your right.
Lo-Fi Version | Time is now: 17th May 2024 - 06:53 PM |
