Dr Evil
Jan 19 2008, 07:04 PM
OK, so now the question is, what piston do I need? The other 5 original cylinders to the engine say KS, are alusil, are height group 6 and size 0. The one that broke, and was from a different set, was a Mahle piston with a mahle cylinder. this is causing me issues as I do not know what compression ratio piston I need for my 1973.5 2.7L US engine. The two that this one guy is offering me are 90202 or 90208. Which should I take? He also said that a 1973.5 /6 was a 2.4 CIS engine. I think that is incorrect as I have never seen such a beast. MFI yes, CIS no.
sixnotfour
Jan 19 2008, 07:36 PM
true statement
Dr Evil
Jan 19 2008, 07:40 PM
Lernt something today. I am pretty sure it is a 2.7, though and I still need the answer to my question about what piston to get from him. Any ideas, Jeff?
sixnotfour
Jan 19 2008, 07:50 PM
90208 KS 2.7
Dr Evil
Jan 19 2008, 07:51 PM
As always, thanks for your continued help
You da man
degreeoff
Jan 19 2008, 07:59 PM
Hey Mike,
The 73.5 WAS a 2.4...I have one and it is a 2.4....it also has the 7R case (hence why I bought it)....
Dr Evil
Jan 19 2008, 08:19 PM
2.4 WITH CIS? I know that the 2.7 started in 74, I got this engine from a 74, but some of the CIS bits are the earlier bits and why I think it is an early 2.7.
sixnotfour
Jan 19 2008, 08:31 PM
73 had a split between MFI and CIS for the T model, hence 73.5 CIS 2.4
they had steel runner tubes
Dr Evil
Jan 19 2008, 08:35 PM
Ah, I have the cast aluminum tubes. I do have an extra setup with the steel tubes.
alpha434
Jan 19 2008, 08:36 PM
Another thread based on speculation.
It's not very important whether 73.5 was a 2.4 CIS if you have a cluster-fuched 2.7. Measure those things. If you hurry, and you have no calipers, you can buy some from FLAPs before they close.
GO GO GO!
Dr Evil
Jan 19 2008, 08:37 PM
Feel free not to respond to my threads, alfalfa.
Dr Evil
Jan 19 2008, 08:39 PM
What size were the jugs on the 2.4? I know I have 90mm which are the 2.7 so I am not worried about that. I was just wondering if I had the right CIS as well.
sixnotfour
Jan 19 2008, 08:41 PM
check the PN on the fuel distributor.
Dr Evil
Jan 19 2008, 08:43 PM
The p/n is right. I found the size for 2.4 as well, 86mm.
sixnotfour
Jan 19 2008, 08:53 PM
84mm
Dr Evil
Jan 19 2008, 09:03 PM
Strike!
Hey Jeff, would I be correct in thinking that the number you recommended is the lower CR 8:1 74 2.7 piston?
sixnotfour
Jan 19 2008, 09:22 PM
Your right.
