Lowering front end suspension Range of adjustment?, How much adjustment? |
sunsetcoast914 |
Jan 20 2008, 11:30 AM
Unregistered |
Greetings 914 world... :-) I'm putting 110 165 rear springs on which are apx 3/4 shorter than stock. I'll want to lower the front end by 'at least' as much. Could someone tell me how much range is typically available just by turning the adjustment bolt on the torsion bar? Would I need to re index the bar to drop an inch, or is adjustment probably adequate?
Thanks! |
Jan 20 2008, 11:45 AM
Greetings 914 world... :-) I'm putting 110 165 rear springs on which are apx 3/4 shorter than stock. I'll want to lower the front end by 'at least' as much. Could someone tell me how much range is typically available just by turning the adjustment bolt on the torsion bar? Would I need to re index the bar to drop an inch, or is adjustment probably adequate? Thanks! depends on where they are right now. if you still have the full adjustment left, 1" is no problem. if they already bottom out, you'll have to re-index ... (IMG:style_emoticons/default/bye1.gif) Andy PS: (IMG:style_emoticons/default/welcome.png) |
sunsetcoast914 |
Jan 20 2008, 12:29 PM
Unregistered |
QUOTE depends on where they are right now. if you still have the full adjustment left, 1" is no problem. if they already bottom out, you'll have to re-index ... (IMG:style_emoticons/default/bye1.gif) Andy PS: (IMG:style_emoticons/default/welcome.png) Thanks Andy! (IMG:style_emoticons/default/beerchug.gif) Curious if it's linear..uhhh such that the travel of the adjuster = amount of height change... 1 in travel of threads = 1 inch lower? Or is it 'leveraged' somehow so 1/2 inch = 1 inch ht. change etc? Guess Ill find out... I havent checked the current position yet. |
Jan 20 2008, 12:42 PM
Thanks Andy! (IMG:style_emoticons/default/beerchug.gif) Curious if it's linear..uhhh such that the travel of the adjuster = amount of height change... 1 in travel of threads = 1 inch lower? Or is it 'leveraged' somehow so 1/2 inch = 1 inch ht. change etc? Guess Ill find out... I havent checked the current position yet. not linear. i don't know the exact ratio, but the car raises/lowers more than what the adjuster cap travels ... (IMG:style_emoticons/default/bye1.gif) Andy |
McMark |
Jan 20 2008, 03:16 PM
You can raise it up until the suspension binds.
You can lower it down until the suspension binds. And you can set it anywhere in between. And with the removable cap, you don't even have to touch the torsion bar. (IMG:style_emoticons/default/biggrin.gif) You'll have to try something and then adjust, then try again. It takes a little while, and don't forget to roll the car forward and backward after each change. |
sunsetcoast914 |
Jan 20 2008, 04:29 PM
Unregistered |
Thanks for the info and advice guys!!!
Jan 20 2008, 05:32 PM
when the car is sitting on the ground, go no lower than horizontal with the lower part of the front a-arm.
You will notice a small vertical flange on the lower part of the "frame" that the front a-arm can and will hit if you go to low. I have taken a hammer and bent that flange over flat... I have noticed that I can raise/lower the front end just about 1 inch total. Then you have to re-index the cap. I also do not like the adjuster bolt sticking out to far, it just looks like a problem waiting to be hit some day...so I tend to re-index and adjust till the bolt head is just peaking out enough to get a wrench on it. I also found that a simple and almost close way to measure is with a micrometer against the bottom of the bolt and the bottom of the cross member where the bolt goes through...its dame close to the same on both sides...still need to tweek it for corner balance, but its darn close at that point. I am now driving in the winter with snows and I had to raise it up about 1.5 inches from where I had it...it looks like I am ready for a rally now. Rich |
Lo-Fi Version | Time is now: 17th May 2024 - 02:57 PM |
