Progress, Sprayed some primer today |
craig downs |
Jan 20 2008, 06:13 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
After a lot of work I finally primed the interior compartment today.
I stripped off the paint Installed Engman's long stiffener kit, Redid the speaker hole patch in the fire wall Made a hand throttle This is the speaker hole patch before and after Attached image(s) |
toon1 |
Apr 27 2008, 11:49 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
That is a great job Craig! Have you decided about the spray on sound deadener for the firewall? I think having mine sprayed on both sides really helps (and I still plan to use that B-Quite I bought last year as well). (IMG:style_emoticons/default/pray.gif) that looks good craig!! good job. Interiors are not easy to do. I used" quiet car "on the engine bay side of the fire wall. It works good, easy to install and paintable. Keep up the good work |
Lo-Fi Version | Time is now: 20th May 2024 - 11:22 PM |
