Progress, Sprayed some primer today |
craig downs |
Jan 20 2008, 06:13 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
After a lot of work I finally primed the interior compartment today.
I stripped off the paint Installed Engman's long stiffener kit, Redid the speaker hole patch in the fire wall Made a hand throttle This is the speaker hole patch before and after Attached image(s) |
3d914 |
May 25 2008, 02:52 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Very nice work Craig. What was your choice of primer, and how does it fit into your paint method?
I was under the impression that the type of primer had to match the paint method used (single stage, multi-coat, etc), so I've reached a stopping point. I've narrowed the primer down to either Epoxy or Polyester. Since it looks like you used chemical paint remover I suspect you went with an epoxy primer. Keep up the good work & pics. |
Lo-Fi Version | Time is now: 20th May 2024 - 11:49 PM |
