Progress, Sprayed some primer today |
craig downs |
Jan 20 2008, 06:13 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
After a lot of work I finally primed the interior compartment today.
I stripped off the paint Installed Engman's long stiffener kit, Redid the speaker hole patch in the fire wall Made a hand throttle This is the speaker hole patch before and after Attached image(s) |
craig downs |
May 25 2008, 11:38 PM
Thanks Stephen
I used PPG DP40 epoxy primer and had good luck with. I'm planning on using a primer surfacer over it then block sanding it then a sealer before the top coat. You have to make sure that all the primer you use is compatible with each other and your top coat. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:50 AM |
