Progress, Sprayed some primer today |
craig downs |
Jan 20 2008, 06:13 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
After a lot of work I finally primed the interior compartment today.
I stripped off the paint Installed Engman's long stiffener kit, Redid the speaker hole patch in the fire wall Made a hand throttle This is the speaker hole patch before and after Attached image(s) |
craig downs |
May 26 2008, 12:02 AM
Ok guys here is some more.
On to the front where I install a sway bar with Enmans swaybar supports. I then added some more weld to the front panel and wheel house because I replaced those years ago after a accident. I removed the fenders because the doors gaps were to wide and it made it a little easier to work on. They came off easy because I braised them on before. |
Lo-Fi Version | Time is now: 17th May 2024 - 10:29 AM |
