Progress, Sprayed some primer today |
craig downs |
Jan 20 2008, 06:13 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
After a lot of work I finally primed the interior compartment today.
I stripped off the paint Installed Engman's long stiffener kit, Redid the speaker hole patch in the fire wall Made a hand throttle This is the speaker hole patch before and after Attached image(s) |
sww914 |
May 25 2008, 01:19 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
When you're painting interiors, trunks, or engine compartments a very easy way to mask the odd shaped parts like wire harnesses, steering wheels, or shifters is to wrap them with aluminum foil. It's cheap and easy to apply and remove. With tape at 6-8 bucks a roll a couple dollars of foil goes a long way.
computers4kids |
May 25 2008, 01:38 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
When you're painting interiors, trunks, or engine compartments a very easy way to mask the odd shaped parts like wire harnesses, steering wheels, or shifters is to wrap them with aluminum foil. It's cheap and easy to apply and remove. With tape at 6-8 bucks a roll a couple dollars of foil goes a long way. Excellent idea...I never thought of that. |
sww914 |
May 26 2008, 12:06 AM
When you're painting interiors, trunks, or engine compartments a very easy way to mask the odd shaped parts like wire harnesses, steering wheels, or shifters is to wrap them with aluminum foil. It's cheap and easy to apply and remove. With tape at 6-8 bucks a roll a couple dollars of foil goes a long way. Excellent idea...I never thought of that. I never did either. 25 years ago a little tiny old Mexican dude told me- joo white guys don't know how to do nothing. Wrap that sheet in teen foil, ees much faster. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 10:08 PM |
