boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Get into the 21st century the Original CAMP 914 rear trunk shox kit. Shipped to your front door in the USA. Foreign orders please inquire. $40.00 PAYPAL,CASH,MO,CHECK. As always money back if not satisfied.
Included are two shox,swivel bracket and mounting hardware, complete instructions. Craig C. Laughlin CAMP 914 1580 Bedford Ct. Lake Oswego, Oregon 97034 USA Attached image(s) ![]() |
boxstr |
Installed picture of the CAMP 914 rear trunk shox
dwillouby |
Member ![]() ![]() Group: Members Posts: 394 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None ![]() ![]() |
Have you tested these with a fiberglass trunk lid?
David |
boxstr |
Personally I have not. But I have sold four pairs to 914 owners. I recommend using the 20lb shox and possibly mounting one.
Craig C. Laughlin CAMP 914 |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,585 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
If I had a 'glass lid I'd just use a propstick...worked for the GT cars right? Craig...I see that the notch cut out of the car is a lot smaller than the one on the orriginal template instructions. I have yet to install mine, so I might do that little notch like in the picture.
boxstr |
The notch needs to be large enough for the shaft, not the shock body. So if it works and aligns correctly on your car, yes you can make a smaller notch. I have found that not all 914's are alike, Some need a larger notch and some will take a smaller one.
Also for those of you with fiberglass trunk lids CAMP 914 now has the 10lb shox, please advise when placing your orders. CCLINSHOXAREUS |
dwillouby |
I installed my shock kit using the 10 lb units. For my fiberglass this is perfect. Using both shocks makes raising and lowering very smooth.
Only problem was a missing lock cap from one of the shocks. Took one from a junk shock and problem solved. David |
greg.treadway |
914 Nut ![]() ![]() Group: Members Posts: 282 Joined: 16-December 04 From: Marietta, GA Member No.: 3,295 ![]() |
With the shocks in place is there enough room in the trunk for the top to fit and if the top is in the trunk will the shocks work right?
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,336 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
Yes with the shocks installed there seems to be no problem with the roof in the trunk and the shocks continue to work proplerly, I've had mine istalled since the beginning of summer and have had no problems with the roof in the trunk at all. The product seems to work just fine no problems as of yet.
Attached thumbnail(s) ![]() |
ewdysar |
What happens here, stays here. ![]() ![]() ![]() Group: Members Posts: 558 Joined: 29-October 04 From: Altadena, CA Member No.: 3,030 ![]() |
I concur. Trunk shocks in, work great, top fits fine. Doing the front Shocks next.
Another great product... from CAMP 914 (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
Carlitos Way |
I did it MY WAY ![]() ![]() ![]() Group: Members Posts: 1,337 Joined: 14-September 04 From: Simi Valley, CA Member No.: 2,757 Region Association: Southern California ![]() |
Does anybody have a close-up of the mounting hardware installed? I just puchased a kit, but the pictures in the directions are hard to make out.
Thanks, Carlos |
montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
i was wondering if this will allow my trunk to pop-up slightly after pulling my release? i have the release button on the inside of the car.
JmuRiz |
I was missing the locking caps (2 of the 4) on the rear set I got. Anyone know where I can get 2 of the lock caps/tabs? I went to a boat store and they have a different style of end now. Thanks for any suggestions!
Update: Craig sent me the missing caps. I'll post pics of the install when I get around to it. |
Lo-Fi Version | Time is now: 11th July 2025 - 02:09 AM |
