Seat Removal, How do I get these *^&$%& things out! |
TeenerTim |
Feb 2 2008, 11:41 AM
Senior Member Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
I've looked at the manual and tried the search here. How do I get these stupid things out. (IMG:style_emoticons/default/sawzall-smiley.gif)
iamchappy |
Feb 2 2008, 11:48 AM
Two ways, they come off the sliders if you shove a long screw driver down the rail with the notched spring clip that serves as a stop for the seat, or remove the 4 - 10mm bolts that hold the rails to the floorboard hinge.
jasons |
Feb 2 2008, 11:52 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Yeah, one rail has a spring that will catch on a stop. You can move the seat all the way forward until it hits the stop. Use your hand and push the spring up into the rail, and the seat will slide off the tracks.
dr914@autoatlanta.com |
Feb 2 2008, 11:59 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I've looked at the manual and tried the search here. How do I get these stupid things out. (IMG:style_emoticons/default/sawzall-smiley.gif) If you still have trouble call me and I will describe the process. |
Feb 2 2008, 12:46 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Yeah, one rail has a spring that will catch on a stop. You can move the seat all the way forward until it hits the stop. Use your hand and push the spring up into the rail, and the seat will slide off the tracks. (IMG:style_emoticons/default/agree.gif) slide forward until it hits the stop, reach under the rail and push up the leafy spring and slide all the way out ... (IMG:style_emoticons/default/bye1.gif) Andy |
VaccaRabite |
Feb 2 2008, 01:34 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
HA! I remember the day I took my seats out. Took me a solid 2 hours to figure it out. Post 3 has the answer you want, though. Once you get the first one, the second is easier.
Zach |
race914 |
Feb 2 2008, 02:05 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
My seat is out so I took a pic of the rail spring. The spring is on the left side rail. The front of the seat is to the left. If you look at the spring along the long slot, you can see the screwdriver marks where I push the spring up to get over the peg on the rail. You have to hold the spring up with the screwdriver in your left hand, and push the seat forward at the same time with your right.
TeenerTim |
Feb 2 2008, 02:33 PM
Thanks everyone. It's been 10 years since my last teener. The seat slider handle was broken and the seat was all the way back so I couldn't see the rear bolts. First time with a fixed passenger seat too but that was a no brainer. Thanks again. (IMG:style_emoticons/default/pray.gif)
KELTY360 |
Feb 2 2008, 05:33 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Great timing on this thread. I didn't know about the spring release and had always undone the bolts at the rear which can be a PITA getting them back on. Had to replace my e-brake warning light switch today and removing the seat with the spring release was much easier.
(IMG:style_emoticons/default/biggrin.gif) |
tracks914 |
Feb 2 2008, 06:18 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I can go into my car and have the seats out in about 2 minutes. It's easy as pie once you know what to do.
degreeoff |
Feb 2 2008, 06:25 PM
I like big butts and I can not lie! Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
I used to take mine out just to have a comfy seat @ BBQ's...like my old VW Bus too those were super comfy!
Lo-Fi Version | Time is now: 16th May 2024 - 08:33 AM |
