Put my Tarett bar together last night and..., I got some ?'s |
Dave Cawdrey |
Mar 20 2003, 12:07 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Put it all together and need some answers.
1st: I didnt get any nylock nuts (6 needed) for mounting the bearing blocks to body. Easy fix but, shouldn't they come w/ the set up? 2nd: My car didnt have an existing bar and I need a template to locate the holes. Anyone have such a thing? TIA |
ChrisReale |
Mar 20 2003, 12:30 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
QUOTE(Matt914MI @ Mar 19 2003, 10:28 PM) You shouldn't tap the "hoes" you know. :P Speaking of sway-bars, what size/grade nuts and bolts should I use on the factory mounts for a factory bar? The car originally had one, but I one of the POs sold it or something. So I have the holes there already, and I got mounts with the used bar I bought that seem to be fine, but I don't know if normal nuts and bolts would shake themselves loose. I have to order new bushings for it before I install it anyway, so should I order some special locknuts or something along with them? If so, where should I get them? Thanks guys. -Matt Nylock nuts are supplied with the Tarett. I can give you the torque numbers tommorow. I cant go to the garage right now, its almost past my bedtime (IMG:style_emoticons/default/laugh.gif) edit*****Brad you type too fast...plus you have a guest to entertain (IMG:style_emoticons/default/mueba.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 02:53 PM |
