how large are you nuts?, valve retaining nuts on adjusting screws |
nebreitling |
Jan 10 2004, 07:06 PM
hi all, i'm adjusting the valves
the pelican article says that the retaining nuts are 13mm -- mine are 14 (and tight as hell, i can't budge them)... is this common, or has a PO done some crazy stuff on me? |
TheCabinetmaker |
Jan 10 2004, 07:17 PM
I keep the valves right on 6 different cars locally. The 1.7 have been 13 mm. the 2.0's are 14mm. All are 73 and later cars
nebreitling |
Jan 10 2004, 07:25 PM
great, thanks.
any tips on loosening them up, without stripping them? i just had a 14mm socket do a number on one of those nuts... n |
JeffBowlsby |
Jan 10 2004, 07:30 PM
914 Wiring Harnesses Group: Members Posts: 8,515 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Use a box wrench.
Also, be sure that the cylinder you are adjusting is at TDC, or the valves will be too tight to adjust. Jeff |
TheCabinetmaker |
Jan 10 2004, 07:34 PM
try a long 6 point box end wrench. I never use a socket. might be better to remove the rocker arms, and loosen the adjuster nuts on a bench.
nebreitling |
Jan 10 2004, 07:53 PM
QUOTE(bowlsby @ Jan 10 2004, 05:30 PM) Also, be sure that the cylinder you are adjusting is at TDC, or the valves will be too tight to adjust. maybe i'm a TDC #3 then; because there is NO gap that i can discern between the adjusting screw and the valve. the rockers are tight at #1! BUT, the impeller marks (which i found and remarked -- there was confusion in a previous post of mine) show TDC. i DID recently re-index the distributor drive shaft (long story) -- can that be 180 degrees off and still show TDC on the impeller? |
TheCabinetmaker |
Jan 10 2004, 08:01 PM
Is there an indexing mark on the top of the dizzy body? it's a small notch. the rotor should be pointing to this area if your on #1 if your not 180 off. Regradless, the rotor should point towards the # 1 wire on the cap.
Lo-Fi Version | Time is now: 24th May 2024 - 05:10 AM |
