QUOTE(bowlsby @ Jan 10 2004, 05:30 PM)
Also, be sure that the cylinder you are adjusting is at TDC, or the valves will be too tight to adjust.
maybe i'm a TDC #3 then; because there is NO gap that i can discern between the adjusting screw and the valve. the rockers are tight at #1!
BUT, the impeller marks (which i found and remarked -- there was confusion in a previous post of mine) show TDC.
i DID recently re-index the distributor drive shaft (long story) -- can that be 180 degrees off and still show TDC on the impeller?
