montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
Let me look for it, That was done years ago and I think that file is on my old computer. If I can't find it, I will model it again. Should only take me an hour or so.
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Small parts for real--- 1:1 scale plastic small (IMG:style_emoticons/default/beerchug.gif) parts. What a business you could do.
montoya 73 2.0 |
Thats what I'm hoping for!
LotusJoe |
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California ![]() |
Thanks to Drew for finding the files. I printed out a couple of funnels on my printer and your drawing was spot on perfect. I'm very happy with the results. Now I guess the questions is there a big enough demand to make a run of them (IMG:style_emoticons/default/confused24.gif)
chads74 |
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States ![]() |
Very cool!
montoya 73 2.0 |
is that ABS plastic?
BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
Looks like the abs printer.
Cool stuff!!!!! |
LotusJoe |
LotusJoe |
We also just bought a Romer 7 axis laser scanning arm to do rapid prototyping. Cool thing is we can scan an object, clean it up a little and go straight to STL and then print.
montoya 73 2.0 |
I was looking at the new 2 axis makerbot that is to be released this year. I'm also interested in a scanner by 3D3 "Flexscan" that uses white light or they call structured light. Any advice?
LotusJoe |
I was looking at the new 2 axis makerbot that is to be released this year. I'm also interested in a scanner by 3D3 "Flexscan" that uses white light or they call structured light. Any advice? We are using Geo magic software with our scanner. For an inexpensive scanner we have also hooked up the XBox Kinects to the software and had good results. I don't have any experience with Flexscan but looks to be decent equipment. ![]() Also just ordered the new Replicator II but it has not arrived yet. Hoping for better build quality. ![]() I was checking out the availability of the rain funnels, and found them at Auto Atlanta for $14.00, so it doesn't look as though there would be a market to make a run of them. But it was fun to take your drawing and test it out. By the way, nice drawing, we did not have to do anything with it except rotate it to sit on the platform. |
montoya 73 2.0 |
I like that kinect idea. I was only going to use their software not the camera. I was looking at MBII, that has a 8 week lead time. I really want the MB2x.
Thanks, all my models are .stl ready for proto-3Dprinting. I'm buiding a library of parts so when I get the printer I can keep it busy for awhile. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
That's pretty much what I've found for many of these parts. There is some cool technology to make one off parts inexpensively, but any time you up the volume the manufacturing cost is the same. One part for $14, is cool. 100 parts, + cost of equipment and other incedentals is $1300+. There is no real economy of scale, but great if you need a part now and have the talent to draw, or can scan a good one.
montoya 73 2.0 |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
[/quote] We are using Geo magic software with our scanner. For an inexpensive scanner we have also hooked up the XBox Kinects to the software and had good results. I don't have any experience with Flexscan but looks to be decent equipment. ![]() [/quote] that looks like you have a hand held handle for the kinect. are you able to use it as a hand held scanner, and get multiple angles? |
ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
We also just bought a Romer 7 axis laser scanning arm to do rapid prototyping. Cool thing is we can scan an object, clean it up a little and go straight to STL and then print. ![]() Can you get your 914 into work and scan the body? (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 17th July 2025 - 04:11 AM |
