How to distinguish 2.0 from 1.8 engine by visual inspection?, any other major visual clues? |
levonfarra |
Feb 19 2008, 11:09 PM
Member Group: Members Posts: 173 Joined: 10-February 07 From: Encino, CA Member No.: 7,521 Region Association: None |
What is the easiest way to tell the differances between 2.0 and 1.8 when looking into the engine bay?
Are the airboxes different? Any other visual clues? Are the mufflers different? Thank you, Levon (IMG:style_emoticons/default/smile.gif) |
computers4kids |
Feb 19 2008, 11:20 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
What is the easiest way to tell the differances between 2.0 and 1.8 when looking into the engine bay? Are the airboxes different? Any other visual clues? Are the mufflers different? Thank you, Levon (IMG:style_emoticons/default/smile.gif) A few quick items...
McMark |
Feb 19 2008, 11:24 PM
Edited above for clarity... (IMG:style_emoticons/default/cool.gif) |
alpha434 |
Feb 19 2008, 11:50 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
The big aluminum air flow sensor on the left side of the bay, with the air filter all the way on the left side is typically a dead give away that it's a 1.8
Also, the distributor. Should be a bosch 027 with vacuum advance, and no extra wires coming out for the firing the sequential injection. |
Brando |
Feb 20 2008, 09:05 PM
Can't really rely on the distributor as most of these cars don't have the original one in it.
You can tell by the engine number if it is still there. EA = 1.7 EC = 1.8 GA/GC = 2.0 |
alpha434 |
Feb 20 2008, 10:11 PM
Well. a 1.8 can't run a 1.7 dizzy. Or a 2.0 dizzy. And a 1.7 and 2.0 can't run a 1.8 dizzy.
Stock or not, they have to have the extra rotor for the d-jet' sequential injection. Unless it's carbed- then we've got a whole 'nother cluster-fuch. |
John |
Feb 20 2008, 10:39 PM
Well. a 1.8 can't run a 1.7 dizzy. Or a 2.0 dizzy. And a 1.7 and 2.0 can't run a 1.8 dizzy. Stock or not, they have to have the extra rotor for the d-jet' sequential injection. Unless it's carbed- then we've got a whole 'nother cluster-fuch. Extra rotor? Never saw one. I have seen trigger points if that's what you refer to. On stock engines, there are also differences in the oil filler neck. |
JRust |
Feb 20 2008, 11:36 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Also the FI brain is smaller on the 1.8 than the 2.0 .
jesiv |
Feb 24 2008, 01:46 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Engine number location 2.0 up near the oil filler on 1.8 back of the engine and or course once you know what l-jet look like you can always tell. I didn't know either... That's how I ended up with a 1.8 instead of a 2.0. Duh...
If you can't tell find someone who can. James |
Cevan |
Feb 24 2008, 04:28 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
orthobiz |
Mar 3 2008, 06:59 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
easiest way: if it has original FI::::::
the air cleaner box on the 2.0 has the intake spout PARALLEL to the rear line of the trunk the 1.8 is off on an angle many, many times you see just a little bit of this in a picture of the engine compartment and you can ALWAYS tell Another easy way: if it's an advertisement and it DOESN'T say "2.0" you're just about guaranteed it's a 1.8!!! Paul |
jesiv |
Mar 3 2008, 07:12 PM
Had this issue Sunday. Ad was for 1975 2.0 running engine and trans without FI for $250. Yes I was there at day break. Immediately looked for engine number by the Oil filler no number. Looked to the rear and there it was... 1.8 engine number. Owner response was will the PO said it was a 2.0 and all I know are bug engines.
So if it sounds too good to be true it usually is... Engine number is really the only way to know a 2.0 |
Cap'n Krusty |
Mar 3 2008, 07:41 PM
Well. a 1.8 can't run a 1.7 dizzy. Or a 2.0 dizzy. And a 1.7 and 2.0 can't run a 1.8 dizzy. Stock or not, they have to have the extra rotor for the d-jet' sequential injection. Unless it's carbed- then we've got a whole 'nother cluster-fuch. There's NO earthly reason why a 1.7 or 2.0 distributor can't be used in a 1.8.. you're right though, you can't run D-jet with a 1.8 distributor. The Cap'n |
ClayPerrine |
Mar 3 2008, 10:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Well. a 1.8 can't run a 1.7 dizzy. Or a 2.0 dizzy. And a 1.7 and 2.0 can't run a 1.8 dizzy. Stock or not, they have to have the extra rotor for the d-jet' sequential injection. Unless it's carbed- then we've got a whole 'nother cluster-fuch. There's NO earthly reason why a 1.7 or 2.0 distributor can't be used in a 1.8.. you're right though, you can't run D-jet with a 1.8 distributor. The Cap'n And D-Jet is NOT sequential injection. Sequential means that it fires the injector in time with the valve opening. D-Jet fires the injector in pairs. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:49 PM |
