| mdwman |
Feb 21 2008, 01:52 PM
Member ![]() ![]() Group: Members Posts: 65 Joined: 28-May 07 From: Tennessee Member No.: 7,764 |
Getting ready to do a first oil change on my 914 and want to clean the oil strainer as well. I don't have a torque wrench and Autozone has a very inexpensive beam type. I have never used a torque wrench before and wonder if this type is adequate to get the correct torque of 9lbs on the strainer nut? Looks like 2lb graduations on the scale up to 150. The fancy click type wrenches look to be very expensive and many don't go below 10lbs.
Thanks for any input. M |
| SLITS |
Feb 21 2008, 02:29 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
1/4" drive rachet and don't LEAN on the wrench .... just snug 'em about 1/4 turn beyond contact. If it leaks ... give it another 1/8 turn.
You need an in/lb torque wrench ... the cheapies aren't all that accurate. Do it by feel grasshopper .... do it by feel. |
| Van |
Feb 21 2008, 02:36 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
Correct - use a ratchet that is about a foot long, and exert about the the force it takes to pick up a gallon of milk. (One foot - 8.5 lbs... see where this is going?)
| degreeoff |
Feb 21 2008, 02:53 PM
I like big butts and I can not lie! ![]() ![]() ![]() Group: Members Posts: 1,622 Joined: 9-February 03 From: Booowieeee MD (near DC) Member No.: 275 Region Association: MidAtlantic Region |
OR just break down and buy a nice T wrench and you'll never need another. (well maybe 2 alltogether) I have a $69 BAW (to 150lbs) and a $129 Craftsman that goes down to 5 lbs. Needed it for my 9eleben motor....:-P
| purple |
Feb 21 2008, 06:23 PM
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I got a nice Kobalt 3/8'' at Lowe's for 69 bucks and have used it OODLES of times. They really are nice tools because you dont get something us gun owners know all about...parallax error. If you look at a beam scale TW from the wrong angle and not dead on, you're in trouble.
you could also measure the length of your ratched, get a newton spring scale, and then do the torque calculation for what you need. T = Force * Length 10 pounds force @ 1 foot = 10 ft/lbs maybe a bit complex for the uninitiated out there, but it works! oh, the kobalt wrench goes all the way down to 0 in .5 increments. It's hot secks. just get one and cry once instead of every time you try and use a beam wrench |
| Katmanken |
Feb 21 2008, 07:42 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Actually, as a geek engineer, I like the beam type better and think you get better accuracy. I've never had a parallax problem, mine has the indicator real close to the numbers.
With strainer nuts, I go by feel. Just don't be a ham handed torqueing fool. Ken |
| SGB |
Feb 21 2008, 08:50 PM
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Lo-Fi Version | Time is now: 7th June 2026 - 02:31 AM |
