Now, to tune the weber 40 IDF |
purple |
Feb 21 2008, 11:26 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
I know it's been rehashed over and over again....
I have some questions on how to do it after futzing around in the garage trying to make SOMETHING happen. I followed the carb clinic instructions to the T and I think something is adjusted wrong... Maybe you guys can help. I have the idle speed screws to 1/2 turn past first contact with the arms linkage disconnected air bypass screws all the way shut. all mixture screws out 1.5 turns it'll start and run (slowly) and it'll get to what i think is around 450 rpm or something. really slow.. the only way I can get it to idle at 450 or so is by having the mixture screws in pretty far. two cylinders dont even react past a certain point! i can have them all the way in (lightly) and the engine doesnt change its note at all! Please ask me questions so I can give the right info. I've never done this before but i'd like to believe these arent fiddly carbs. When they say the engine should 'speed up' is it a really noticeable change? because mine's so subtle as to be not affected. please help guys! these are brand new carbs from jake's store. I have the box that says what the jetting is. i'll post that soon. what are 'jets' and what do they do? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:18 PM |
