Clutch cable stretching |
mike373 |
Feb 22 2008, 02:22 PM
Member Group: Members Posts: 198 Joined: 3-August 05 From: san diego, ca Member No.: 4,536 |
How much stretching is normal??? I have adjusted it 3 times already since the new cable was installed, about 4 months ago.
Mike |
blitZ |
Feb 22 2008, 02:30 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Do you have 2 nuts securing the cable at the fork? With just one it loosens itself. Also, check to see if the clutch tube is secure.
ws91420 |
Feb 22 2008, 02:32 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
May be a clutch job in the future for you.
jasons |
Feb 22 2008, 03:34 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I don't know but I have had a similar experience. I swear mine stretches as the car gets heat soaked. Specifically, when the car is cold it functions fine. As it gets hot (heat soaked), it seems to stretch.
I have a new OEM replacement cable and a Eurorace header. And, my cable is sheathed with a heat resistant wrap. I've considered trying a Terry Cable. |
Cap'n Krusty |
Feb 22 2008, 04:02 PM
Better check the clutch cable tube where it exits the tub. If there's cracking there, best fix it right away. Might get a flashlight and a mirror and check the end just forward of the shifter, too. The Cap'n
mike373 |
Feb 22 2008, 05:08 PM
Ok... I guess I should give more info.
All clutch parts are brand new and went in the car with my new 2056 engine that I finished building in October. Cable is a new terry cable. This is the thrird time I have tightened it. And now it is hard to get in gear when clutch is to the floor. Mike |
Feb 22 2008, 05:16 PM
Better check the clutch cable tube where it exits the tub. If there's cracking there, best fix it right away. Might get a flashlight and a mirror and check the end just forward of the shifter, too. The Cap'n (IMG:style_emoticons/default/agree.gif) sounds like your clutch tube is giving away ... (IMG:style_emoticons/default/shades.gif) Andy |
mike373 |
Feb 22 2008, 06:35 PM
Nooooooooooo !!!!!!!
Feb 22 2008, 11:04 PM
Or, as was mentioned above, you're not double-nutting it. Even Nylocs slip on the clutch cable on my car.
--DD |
orthobiz |
Feb 23 2008, 02:06 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
I've heard not to reuse the Nyloc nut. Unless it's new it'll definitely slip. But double nutting is the best!
And I've decided it's NOT your clutch tube (only because I could never wish that on a fellow teener!). Paul |
mike373 |
Mar 5 2008, 08:07 PM
....and it is double nutted. Haven't had a moment yet to get under there and inspect the clutch tube. Damn!!!!
Engman |
Mar 5 2008, 08:32 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
In what type of condition is your pedal board?
M |
mike373 |
Mar 6 2008, 06:58 PM
I was thinking about that too. The pedal cluster needs a rebuild and still has the nylon bushings. Maybe the bushings are opening up and I'm losing clutch cable pull??
(wishfull thinking) Mike |
Lo-Fi Version | Time is now: 17th May 2024 - 02:11 PM |
