mike373
Feb 22 2008, 02:22 PM
How much stretching is normal??? I have adjusted it 3 times already since the new cable was installed, about 4 months ago.
Mike
blitZ
Feb 22 2008, 02:30 PM
Do you have 2 nuts securing the cable at the fork? With just one it loosens itself. Also, check to see if the clutch tube is secure.
ws91420
Feb 22 2008, 02:32 PM
May be a clutch job in the future for you.
jasons
Feb 22 2008, 03:34 PM
I don't know but I have had a similar experience. I swear mine stretches as the car gets heat soaked. Specifically, when the car is cold it functions fine. As it gets hot (heat soaked), it seems to stretch.
I have a new OEM replacement cable and a Eurorace header. And, my cable is sheathed with a heat resistant wrap.
I've considered trying a Terry Cable.
Cap'n Krusty
Feb 22 2008, 04:02 PM
Better check the clutch cable tube where it exits the tub. If there's cracking there, best fix it right away. Might get a flashlight and a mirror and check the end just forward of the shifter, too. The Cap'n
mike373
Feb 22 2008, 05:08 PM
Ok... I guess I should give more info.
All clutch parts are brand new and went in the car with my new 2056 engine that I finished building in October. Cable is a new terry cable. This is the thrird time I have tightened it. And now it is hard to get in gear when clutch is to the floor.
Mike
Feb 22 2008, 05:16 PM
QUOTE(Cap'n Krusty @ Feb 22 2008, 02:02 PM)
sounds like your clutch tube is giving away ...
Andy
mike373
Feb 22 2008, 06:35 PM
Nooooooooooo !!!!!!!
Dave_Darling
Feb 22 2008, 11:04 PM
Or, as was mentioned above, you're not double-nutting it. Even Nylocs slip on the clutch cable on my car.
--DD
orthobiz
Feb 23 2008, 02:06 PM
I've heard not to reuse the Nyloc nut. Unless it's new it'll definitely slip. But double nutting is the best!
And I've decided it's NOT your clutch tube (only because I could never wish that on a fellow teener!).
Paul
mike373
Mar 5 2008, 08:07 PM
....and it is double nutted. Haven't had a moment yet to get under there and inspect the clutch tube. Damn!!!!
Engman
Mar 5 2008, 08:32 PM
In what type of condition is your pedal board?
M
mike373
Mar 6 2008, 06:58 PM
I was thinking about that too. The pedal cluster needs a rebuild and still has the nylon bushings. Maybe the bushings are opening up and I'm losing clutch cable pull??
(wishfull thinking)
Mike
