Turning /6 headers into heat exchangers, Just postulating |
TimT |
Feb 25 2008, 09:38 PM
try these Looky
rktmn247 |
Feb 25 2008, 10:25 PM
Irish Green with GT envy! Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None |
Or do what I am thinking about. I'm doing a /6 conversion with headers and a front mounted oil cooler. I am thinking about building a heat exchanger/box heated by the hot oil before it goes to the cooler. Seems simple enough? Just need to figure out what to use for the heat exchanger? Oil doesn't get hot enough. Your talking 300 to what over 600 deg. Coolant temps in water cooled engines are around 180 deg. so why wont this work? |
Root_Werks |
Feb 25 2008, 10:54 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
do what PMS does and simply box a section of the headers and blow air through ... do NOT weld the box to the headers, just make two halves and pinch/press them together. this will work fairly well ... (IMG:style_emoticons/default/smash.gif) Andy (IMG:http://www.patrickmotorsports.com/parts/724.jpg) I have had a pair of the B&B stainless Steel heater boxes on my 914 for almost 2 years now. They have good air flow, but don't really get all that hot which isn't needed in my area. So they work really well. They were $1800 back then. I remember the tube idea I did and is probably still on the flared orange six I did years ago. It worked REALLY well in town until you got on the freeway, then the tubes cooled down to almost cold air. But in town it was really nice and toaty warm. Wish I could have tried insulating the tubes. |
Feb 25 2008, 11:19 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm doing a /6 conversion with headers and a front mounted oil cooler. (IMG:style_emoticons/default/agree.gif) that should work, but you'll need to plumb it a bit different so that you can suck in the warm air with the stock fresh air blower. in the stock configuration, the fresh air blower never sucks in the hot air from the ducts in the longs. in order to force air through the cooler (think stop & go traffic), you will have to modify your airbox to suck from the warm air inlets ... (IMG:style_emoticons/default/shades.gif) Andy |
messix |
Feb 25 2008, 11:26 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I'm doing a /6 conversion with headers and a front mounted oil cooler. (IMG:style_emoticons/default/agree.gif) that should work, but you'll need to plumb it a bit different so that you can suck in the warm air with the stock fresh air blower. in the stock configuration, the fresh air blower never sucks in the hot air from the ducts in the longs. in order to force air through the cooler (think stop & go traffic), you will have to modify your airbox to suck from the warm air inlets ... (IMG:style_emoticons/default/shades.gif) Andy just run a something like a tranny cooler on the scavenge side that would be mounted inside a box that the heater blower would blow thru then on to long duct. |
Feb 25 2008, 11:31 PM
just run a something like a tranny cooler on the scavenge side that would be mounted inside a box that the heater blower would blow thru then on to long duct. yeah, but he was talking about a front mounted engine oil cooler. which is what i have. it gets plenty up front, but when you're in stop/go traffic, there's no forced air flow, thus you wouldn't get any warm air inside the cabin. the fresh air blower is in the perfect place to be reused to blow the warm air from the front cooler into the cabin ... (IMG:style_emoticons/default/smash.gif) Andy |
Dr Evil |
Feb 26 2008, 08:38 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Good discussion going on here (IMG:style_emoticons/default/smile.gif)
rick, I dont need a set of HEs. luckily, but thanks for the offer. I have a nice set of stockers for my /6 that were donated and salvaged through the net work here (IMG:style_emoticons/default/smile.gif) I am just thinking of ways to warm the cars because it is cold here and I am going to need to put some type of HE system on my future bus/vair conversion some day (oh no, here he goes again with the damn vair). I like the cessna HE idea. I bet I cold make something similar for less. The problem with Dan's set up with the pipes is that there is not enough surface area to get heat saturated and combat the airs cooling effect. In particular, with internal surface area that is not exposed to the cooling air flow, you would be able to keep the air warm. Is it OK to weld stainless to stainless in the idea that I had with the fins? As for the oil cooler concept, Rennegade already has a water cooled set up that employs many of the concepts you guys are talking about, but with water. I bet you could copy their blower set up and plumbing for the oil lines and put them in the same place as the heater core would have gone. You may even be able to utilize a smaller front cooler as the heater core, even when not in use, would provide extra surface area for shedding heat. I would even immagine that plumbing the oil cooling system would be easier as the lines would be smaller than the H2O stuff. Would you need an extra oil pump to flow through all of that plumbing and the cooler, though? |
Eric_Shea |
Feb 26 2008, 09:13 AM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I like the cessna HE idea. I bet I cold make something similar for less. (IMG:style_emoticons/default/av-943.gif) They're $100 bucks... (IMG:style_emoticons/default/confused24.gif) I think that's one of the best ideas I've seen presented here in a long time. $400 GPR Headers $250 Heat Boxes $650 for a new system out the door? No brainer. |
So.Cal.914 |
Feb 26 2008, 09:25 AM
QUOTE As for the oil cooler concept, Rennegade already has a water cooled set up that employs many of the concepts you guys are talking about, but with water. I bet you could copy their blower set up and plumbing for the oil lines and put them in the same place as the heater core would have gone. You may even be able to utilize a smaller front cooler as the heater core, even when not in use, would provide extra surface area for shedding heat. I would even immagine that plumbing the oil cooling system would be easier as the lines would be smaller than the H2O stuff. Would you need an extra oil pump to flow through all of that plumbing and the cooler, though? That should work. It is such a short trip from the front of the car to the blower box I doubt you would need to up grade the oil pump. |
Dr Evil |
Feb 26 2008, 09:51 AM
Ah, I ass-u-med that since they were aviation they were expensive.
andys |
Feb 26 2008, 11:32 AM
I built some heater boxes some 30 years ago on a turbo 914. The Crown kit headers didn't have any, so I made my own which worked as well as the stock ones. Notice that the stock heater boxes on a -4 are pretty long, and the air flow runs down one side, makes a turn ,and returns to the front. Plenty of time/surface area to heat the air. I employed the same thinking when I built mine making sure the devious path idea was copied. I basically brazed some sheet metal boxes together.
Andys |
IronHillRestorations |
Feb 26 2008, 12:57 PM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Heat doesn't have to travel far in a small aircraft.
Anyone with vintage heat exchangers would probably be well served with this little CO1 dectector. http://www.wicksaircraft.com/catalog/produ...2816/index.html |
Feb 26 2008, 02:04 PM
914 Idiot Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Remember that oil usually takes quite a while to come up to temp--longer than the coolant in a water-cooled car. And you usually want a thermostat to keep cold oil out of your cooler (for various reasons), which means that in cold weather you may not get heat for a looooooooong time...
--DD |
rfuerst911sc |
Feb 26 2008, 05:49 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Remember that oil usually takes quite a while to come up to temp--longer than the coolant in a water-cooled car. And you usually want a thermostat to keep cold oil out of your cooler (for various reasons), which means that in cold weather you may not get heat for a looooooooong time... --DD That is a valid point but I'm in Orlando Florida where it get's into the 30's for maybe 1 week out of the year. I'm really looking to add some heat don't really need that much. If I'm running oil lines up front for a cooler anyway I think building a small heater box in the front trunk to go between the engine and the cooler would be relatively easy. Just in the concept stage. |
Root_Werks |
Feb 27 2008, 08:17 AM
I like the cessena HE idea. Get some basic headers and weld some heat sinks(fins) on them, wrap them in the aviation HE's and see how it works.
Mister Evil, you gonna give it a whirl? |
Dr Evil |
Feb 27 2008, 08:24 AM
Eric_Shea |
Feb 27 2008, 10:35 AM
QUOTE I just like to think out loud. Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp, Chirp... (IMG:style_emoticons/default/locust.gif) (IMG:style_emoticons/default/biggrin.gif) |
slackin' at work |
Feb 27 2008, 11:07 AM
i should be working Group: Members Posts: 265 Joined: 12-October 07 From: charlottesville, va Member No.: 8,215 Region Association: MidAtlantic Region |
these are awesome:
http://www.webastoshowroom.com/blueheat/index.html gas heaters. they will cook you out of your car. I had on in a ghia vert. the new ones are much more "safe" than the old 50-60's vw/porsche versions. a little pricey at 1800 (installed) but if you want real heat in an aircooled car... this is the only way to go. |
Dr Evil |
Feb 27 2008, 01:06 PM
these are awesome: http://www.webastoshowroom.com/blueheat/index.html gas heaters. they will cook you out of your car. I had on in a ghia vert. the new ones are much more "safe" than the old 50-60's vw/porsche versions. a little pricey at 1800 (installed) but if you want real heat in an aircooled car... this is the only way to go. Nah, I want to salvage gas milage, $$$ and such. You can heat an air cooled without one of those. The heating systems just need to be maintained once they are functional. Eric, (IMG:style_emoticons/default/KMA.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 12:29 PM |
