Best inexpensive header, suggestions? |
jd74914 |
Mar 4 2008, 08:19 PM
Its alive Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
hold on...13ga sheet metal? as in .0897 inches thick? that holds up to anything? what is is that? Like 3/32'' ? i was thinking something a little more substantial would do the trick? am I wrong? http://www.coasteltools.com/tech_steel_gauge_chart.htm is where i get the number A piece the size used (approximately) can hold ~1000# before it breaks. (IMG:style_emoticons/default/laugh.gif) |
purple |
Mar 4 2008, 10:48 PM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
whelp, I found some 12ga (IMG:style_emoticons/default/happy11.gif) galvanized steel strip at lowe's and got a grade 8 bolt and some nuts and went to town.
I had to pull really hard to get the heat sleeve un-melted from the clutch cable and I have to run the clutch cable underneath the engine mount bar, but i duplicated what racer chris did and it works beautifully! If i'd run the clutch thru the mount bar, it would still be all on the header. As a side note, i also fixed my timing and synched my carbs tonight too. talk about getting a lot of stuff done! eurorace...FTW! (IMG:style_emoticons/default/driving.gif) |
VaccaRabite |
Mar 5 2008, 01:08 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
whelp, I found some 12ga (IMG:style_emoticons/default/happy11.gif) galvanized steel strip at lowe's and got a grade 8 bolt and some nuts and went to town. I had to pull really hard to get the heat sleeve un-melted from the clutch cable and I have to run the clutch cable underneath the engine mount bar, but i duplicated what racer chris did and it works beautifully! If i'd run the clutch thru the mount bar, it would still be all on the header. As a side note, i also fixed my timing and synched my carbs tonight too. talk about getting a lot of stuff done! eurorace...FTW! (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Cause I am probably going to have to do the same thing, now that I have been scared off the header wrap. How long is the piece of metal used to offset the cable pully? Zach |
ChrisFoley |
Mar 5 2008, 02:51 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
The ones I supply with my headers have the bolt holes 7/8" apart.
Lo-Fi Version | Time is now: 7th June 2024 - 07:13 PM |
