Two question's after I installed my Weber Carbs, Throttle cable plate and additional plate |
914chic |
Mar 9 2008, 11:29 PM
Newbie Group: Members Posts: 41 Joined: 31-December 07 From: Huntington beach ca Member No.: 8,521 |
McMark |
Mar 10 2008, 12:00 AM
Here's the bracket I've used on a couple cars.
PeeGreen 914 |
Mar 10 2008, 12:04 AM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I don't see what you're talking about. Maybe I'm just blind. The piece in the middle should be angled up higher I would think. It need to be pulled down by the cable.
Here is a good Idea of what is needed even though it is a little different set-up. Attached thumbnail(s) |
McMark |
Mar 10 2008, 12:55 AM
PeeGreen 914 |
Mar 10 2008, 01:01 AM
When I had a four no. The other ones I have seen look very sharp as well. It is from Triad. Everything on it was solid and smooth. The mount for the cable is very stout.
Wow I feel like a whore for Triad sometimes. I think Dave should make me exhausts for free (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
Mar 10 2008, 07:42 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mark, the triad bracket doesn't flex. i can't tell from jon's picture but mine is bolted up to the forward side/edge of the fan housing. the recess that catches the threaded end of the throttle cable works great too.
k |
pete914 |
Mar 10 2008, 07:52 AM
Member Group: Members Posts: 178 Joined: 21-August 07 From: east coast Member No.: 8,025 |
hey chic,
what kind of dizzy do you plan on using? |
JoeSharp |
Mar 10 2008, 08:39 AM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
I use this one but I run the linkage behind the carbs. It's not going back in the car and you can have it but you will have to turn the carbs around to use it.
wilchek |
Mar 10 2008, 03:33 PM
Senior Member Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
Joe,
If he is not interested and am setting up my carbs and have been looking for a bracket. If he is not interested let me know what you want for it. Chic what linkage are u using and where did you get it? |
914chic |
Mar 14 2008, 08:40 PM
Thanks Joe but instead i will just make my own , and on another not the other plate i was wondering about is this one pictured.The top portion of this carb.
Attached File(s) weber_2.bmp ( 136.46k ) Number of downloads: 37 |
Mar 14 2008, 09:17 PM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
McMark |
Mar 14 2008, 11:32 PM
Andy, did you have torsion springs for the rear lid at that time? Seems like most linkages foul the springs when installed on the rear, like yours are.
914chic |
Mar 15 2008, 07:52 AM
Alright that is what I was wondering because right now I have them set aside and am only running like your set up minus the air horns ( to be bought at a later time ) Thanks
purple |
Mar 15 2008, 08:42 AM
Pigeon feeders attract me Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None |
if you want more ideas...this has helped me
http://www.914world.com/bbs2/index.php?sho...=throttle+cable |
Mar 15 2008, 12:17 PM
Andy, did you have torsion springs for the rear lid at that time? Seems like most linkages foul the springs when installed on the rear, like yours are. nope, the torsion springs are long gone. i like the gas shocks a lot better ... (IMG:style_emoticons/default/shades.gif) Andy |
914chic |
Mar 16 2008, 07:05 PM
also had another question about wiring the coil , I have the yellow wire from the cab fire wall going to the 15 side of the coil wich i think is ignition , and then i have the condensor wire going to the 1 side negative . The only wires i have left are the black wire wich I assume should be the ground side of the coil , but then I still have a (green with red stripe ), (a yellow ,) (black with purple ),( a black with red )and a( green with black) , these wires that i have I do not know where they go? Also being that this was a l jettronic car , The stock distributor is fine right?
Mar 16 2008, 08:09 PM
also had another question about wiring the coil , I have the yellow wire from the cab fire wall going to the 15 side of the coil wich i think is ignition , and then i have the condensor wire going to the 1 side negative . The only wires i have left are the black wire wich I assume should be the ground side of the coil , but then I still have a (green with red stripe ), (a yellow ,) (black with purple ),( a black with red )and a( green with black) , these wires that i have I do not know where they go? Also being that this was a l jettronic car , The stock distributor is fine right? - black/red, 12V from fuse 8, to + on coil - black, from dizzy to - on coil - green, from dizzy to - on coil - black/purple, tach signal to - on coil - green/red, oil pressure switch - green/black, oil temp sender (optional) - yellow, from ignition switch to starter the 1.8L dizzy should work ... (IMG:style_emoticons/default/bye1.gif) Andy |
KaptKaos |
Mar 16 2008, 09:03 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Those carbs like familiar (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 06:23 AM |
