QUOTE(914chic @ Mar 16 2008, 05:05 PM)
also had another question about wiring the coil , I have the yellow wire from the cab fire wall going to the 15 side of the coil wich i think is ignition , and then i have the condensor wire going to the 1 side negative . The only wires i have left are the black wire wich I assume should be the ground side of the coil , but then I still have a (green with red stripe ), (a yellow ,) (black with purple ),( a black with red )and a( green with black) , these wires that i have I do not know where they go? Also being that this was a l jettronic car , The stock distributor is fine right?
- black/red, 12V from fuse 8, to + on coil
- black, from dizzy to - on coil
- green, from dizzy to - on coil
- black/purple, tach signal to - on coil
- green/red, oil pressure switch
- green/black, oil temp sender (optional)
- yellow, from ignition switch to starter
the 1.8L dizzy should work ...
Andy
